  • Replies 92
Cat arrived this morning! how quick is that :laugh: Thanks rob looks great! came in nice box too. Fitted it this afternoon and I am a happy camper.
+ feedback for organising everything so quickly.
Thanks rob!
i hve not got mine yet. has anyone got theirs??? :)
Check your PM I think we misunderstood the next step. Have your cat here, I've PMd my phone number to you, probably easier to sort it out on the phone!
Hi mate thought I'd replied to this one but can't find in the thread. Still with welder, I will keep checking daily and keep you informed
Rob - how's mine going? Is it back from the welder's? Has it been posted yet?
Rgs,
Kot
Hi Rob,
Any update?
Next batch that yours are with are still on way. Your cat has been ordered and paid for but just waiting for the welders to hurry up and then they will all get sent to me at once.
I am interested in A 3" cat and would like to pay the extra $65 to make it bolt on.. for a skyline with a full 3" exhast except my gay 2.5" cat ATM .. is this still avaliable.. and is it still the same price of 280+65 = $345???
Edited by Fugi
Hi Rob,
Its been about 5 weeks now - any ETA for delilvery? I can pick up from the welder if it will make it quicker...
Rgs,
Adam
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
