I got 201.3 rwkw with 651 Nm torque after having my SAFC-II tuned yesterday im happy with it the car feels great
what i want to know is this a good figure for the following mods.
HKS Pod Filter
HKS 3.5" Cat Back Exhaust + 4.5" HKS Muffler
HKS EVC 5 boost controller @ 10psi
Apexi SAFC-II + Tune
Greddy Type R Blow Off Valve
600x300x76 Autobahn88 Intercooler 2.5" piping
Sard Fuel Pressure Regulator
Walbro 500hp Fuel Pump
NGK iridum sparkplugs @ .8mm gap
BP 98 pump gas
Factory: turbo, ECU
Dyno sheet below
https://www.sau.com.au/forums/topic/134528-got-a-dyno-tune-yesterday-2013-rwkw/
Yeh solid result, plenty more power to be made with a aftermarket computer as your A/F reading is floating around a bit. and a bit of fine tuning of your EBC.
Edited by BezerkR32
yea the air fuel ratio is sitting between 11.8 and 12 max at the higher rev range.
Looks like a good result.. How's it feel - what was it before they started tuning??
it was 185 rwkw going way rich after 4000rpm
the car feels much more solid mid and top end. is also much smother and fuel economy is better also.
im pretty happy i was hoping for 215ish but hey im on my way.
:D
Put the cars on the same dyno, on the same day, then compair. That figure is too high in my opinion, especially without a aftermarket ecu, only a cat back exhaust and 10psi :happy:.
mad082, your figure is really unbelievable. Maybe go to the next dyno day in your state, this will give you a fair comparison with other cars and will tell you if your mechanic is "tweaking" the figures :sick:
a dyno is simply a measuring tool for improvement and tuning. comparing one dyno read out in one state to another in another state could be like comparing, well, apples and oranges?!
do more mods to the car and see the improvement that each makes and then u will be heading in the right direction.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
