I got 201.3 rwkw with 651 Nm torque after having my SAFC-II tuned yesterday im happy with it the car feels great
what i want to know is this a good figure for the following mods.
HKS Pod Filter
HKS 3.5" Cat Back Exhaust + 4.5" HKS Muffler
HKS EVC 5 boost controller @ 10psi
Apexi SAFC-II + Tune
Greddy Type R Blow Off Valve
600x300x76 Autobahn88 Intercooler 2.5" piping
Sard Fuel Pressure Regulator
Walbro 500hp Fuel Pump
NGK iridum sparkplugs @ .8mm gap
BP 98 pump gas
Factory: turbo, ECU
Dyno sheet below
https://www.sau.com.au/forums/topic/134528-got-a-dyno-tune-yesterday-2013-rwkw/
Yeh solid result, plenty more power to be made with a aftermarket computer as your A/F reading is floating around a bit. and a bit of fine tuning of your EBC.
Edited by BezerkR32
yea the air fuel ratio is sitting between 11.8 and 12 max at the higher rev range.
Looks like a good result.. How's it feel - what was it before they started tuning??
it was 185 rwkw going way rich after 4000rpm
the car feels much more solid mid and top end. is also much smother and fuel economy is better also.
im pretty happy i was hoping for 215ish but hey im on my way.
:D
Put the cars on the same dyno, on the same day, then compair. That figure is too high in my opinion, especially without a aftermarket ecu, only a cat back exhaust and 10psi :happy:.
mad082, your figure is really unbelievable. Maybe go to the next dyno day in your state, this will give you a fair comparison with other cars and will tell you if your mechanic is "tweaking" the figures :sick:
a dyno is simply a measuring tool for improvement and tuning. comparing one dyno read out in one state to another in another state could be like comparing, well, apples and oranges?!
do more mods to the car and see the improvement that each makes and then u will be heading in the right direction.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
