Just got back from this.. one of the best motoring events you could ever go to. I've been to the GP in Melb and things, and for sheer coolness and variety this event would have to top it. Not only do get to see pretty much every classic car you could imagine, for once you actually get to see them race on a nice tight street circuit right up close. And you can just move around to one of the many awesome vantage points throughout the day. Best of all, only $25 for the whole day.
It's mostly oldies and classics, and they had pretty much most of the classic Bathurst winners, and most of Brocky's old racers -- and they had a bit of a tribute to him which was an emotional event for the rev heads. Ironically (curiously?) the famous A9X Torana broke down during parade lap, and had to be towed around! Even a Pagani fanging it around there, and people just having a heap of fun.
Anyhow, this is still skyline related.. as there are a few shots of the Gibson HR31 and Winfield Bathurst GTR. Was great to see them up in person, and even see under the hood of the infamous GTR, which didn't look all that out there to be honest in terms of GTR.
It's only an hour or so from the Goldcoast, so don't miss out next year if you're a fan of some of the classics.
https://www.sau.com.au/forums/topic/134695-speed-on-tweed/
Yup...its the endurance setup i think...with backup pumps and all. Nothing wrong with a mechanical fuel pump, if anything its reliable seeing no electrics with it, well except whats in the boot. Lovely setup for something thats 14-15 years old. From what SK was saying i think they were around the 600bhp mark originally until they were forced tune it down and add weight - unfortunately thats the disadvantage of being too quick :thumbsup:
Yeh the cylinders one feeds fuel and the other equalises the tank pressure so you can get fuel in as quick as possible, time is everything.
https://www.sau.com.au/forums/topic/134695-speed-on-tweed/#findComment-2507537
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
