Does any one have them?
What are the cost?
Is it possible to integrate one into existing immobaliser and alarm or do I have to install a new unit?
If your talking about remote controls for your alarm then you need to know what brand of alarm/immobiliser you have because not all work with differant brands. Hopefully if the company is still around you can then get replacement remotes which would still need to be tuned in to your alarm.
What are the cost?
do you have a pic of the unit in question?
from there either of us can probably help.
Doesn't appear to be touch screen, just an LCD screen which would show things like which zone has been activated. I've seen similar remotes before, there are buttons on the side.
Searching ebay there seem to be a few GSM alarms floating around the $260~ mark.
Maybe Chris Rogers could indicate which are good and which are rubbish as I am also interested in these alarm systems.
One of the more expensive varient is by rhino going for $400~
http://search.ebay.com.au/search/search.dl...title=gsm+alarm
- Patrick
ala the jaycar bit of rubbish...
seen this thing under so many names its not funny.
also click around that site- none of it works!
Edited by Chris Rogers
- Patrick
christ that rhino one is CHEAP! (I can't even buy it for that!) the rest I would be weary of.
if you want a proper one flick me a PM.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
