Ok so
so far the car has got all the supporting mods
Walbro Gss432 pump
adjustable fuel pressure regulator
full 3" exhaust with dump pipe
HKS pod and intake
boost regulator
SAFC II
FMIC
New 02 sensor
New ECU temp sensor
I am running 7psi at the moment, and when i got o tune the SAFC II i want to run 12psi and no more, less if i can get away with it.
The tunner told me that 160rwKw is basically what is actually posible, i have no idea why, that is only a 40kw increase over stock.
Now basicaly intake and exhaust is a good 10kW, pod 5kW, 5psi boost 40kW, remap, about 10kW so that should be a total gain of about 65kw. Now stock at the RW is about 120-130kW so that should be about 180-190rwKw in total
So what the helll is he on about.
Can people post up their output figures with the mods. I am not too sure if the tuner can be trusted but that is the only one poeple have recomended.
What sourght of power figures should i be looking at, and what do i tell the tuner to do, ie fuel air rations and recomendations to my tune.
HELP PLEASE, i want to get this right, as i am on a budget. Thanks.
SILLY ME. she's a 1995 R33 series 1.5. Opppsa
Edited by WogsRus
https://www.sau.com.au/forums/topic/134905-car-booked-in-for-a-tune-safc-ii/
1.What car is this for btw? R32 Or R33 Or R34?
2. How much power is the car making now prior to installing SAFC + tuning?
3. What turbo are you running? stock?
4. If its a r33 with the mods you have listed on stock turbo i personally believe you'll be getting between 170-190rwkw as well. If its an r32 then 160rwkw is my guess.
my 2cents
remember auto's dont read aswell on dyno's as manuals do,
i was told by my tuner,he said it reads a little higher down low
(something to do with the torque) and read low up top.
89' rb20det r33 turbo+zorst & SAFC1 automatic = 165rwkw
12psi
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
