yeah 301 not bad for a gtr-s turbs/daily driver..
i called up the badge co try get more they have closed down..
spewin cuz i know ima get badged one day soon..
yeah, ima get a couple of badges, im sure there are gts ppl out there and as soon as they see these badges will run right over :laugh:... same about the place closing down.. yeah 301 not bad at all. alot of quality hks stuff in there, love hks!!.. i have a pic of this car in a mag, ill try scan it and see what i come up with.
  • Replies 224
Posted Images
shouldn't be long now fella's spoke to them today and the materials for the prototypes have come in ... so they will probally get done as soon as tomorrow :) ...
fingers crossed!
Might be a bit too late but will throw my idea in for kicks :P
Why cant the design be different to the GTR? Regardless if it will be GTS OR GTT it still mimicks the GTR and may not be spotted from afar as others have mentioned.
Here is a quick 5min job of maybe a whole new design for a badge :)
If someone could pass me the .PSD it will be easier to play around with :cheers:
should be easy enough to get a sticker of the GTS. Was thinking it would be placed on the top right corner of the bootlid, just above the rear light. Just need a proper image file :P
If someone could pass me the .PSD it will be easier to play around with :huh:
The raw artwork is an illustrator file not photoshop and I'm sorry but handing over the artwork is like asking the FBI to handover the xfiles...LOL!
i quite like rekins top design, the one with the larger T. maybe make the 'gts bit white instead of grey for a bit of contrast
haha i dunno, these are just some poor chopping examples. Darkboy should be able to pump out some pro looking ones ;)
i think we should stick with what we know should come out nice and what we know will look good on our cars. those ones with the big t look nice, but what will they look like on?, looks good with the black background, but things may change once its off that?, im likem the original idea
hey guys
still waiting on the prototype ... the people making them are really busy but they assure me it won't be long now =)
Gday Mate,
Hows things going?
We looking at a prototype yet?
R33
Hey Everyone,
I bet by now your all feeling pretty angst about these badges getting made.
I've been having troubles with the company producing them but they assure me it wont be long. I didn't realise the complications of having an outside job done :teehee:.
I promise to get this prototype made asap. (and i'll be really pissed if it takes this long and turns out shit)
Thanks for your patience,
Chris :laugh:
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
