At 3pm i'm going to have a look at a '93 1.8i 5sp soft-top MX5 that my gf wants to buy. I'll be leaving a deposit on it if it all looks good, and possibly pick it up tonight.
Has anyone got any tips on problems or common faults with these models?
Anything in particular to look for ?
This one has 148k on the clock, nice 17" mags, and i've offered 9k over the phone (hopefully bring it down a touch more).
Edited by Munkyb0y
I used to have a 93 but it was a 1.6... i thought that the 1.8 didn't come out til a few years later
things to look for are basically the same as on any car, just pay attention to the roof (old plastic windows tend to tear or be almost non-see thru) anchors. sometimes they are wrecked and you are basically up for a replacement roof...
Other than that they are a great car (a little underpowered) awsome on the twisty bits...
Have a really small boot though....
Good luck
Jdfnq, the 1.8i came out in Nov '93. Will check soft top/anchors thoroughly. It's a girl's car, doesnt need power :rofl:
Thanks for the tip. Do you think 148k is a bit high for those little blender motors?
ctjet, as if i'm gonna drive it, paleeeeeez.
any more tips?
any more tips?
nah the motors are pretty bullet proof.... the 1.6 is anyway, the 1.8 is a heavier motor and therefore the handling is not quite as good as the 1.6...
oh and the 1.6 is quicker (don't ask me why or how, just is)
but if your not driving it i wouldn't stress
148k,s is pretty good.... most of thenm at that age have over 200 on em
yeah i heard that about the 1.6, they reckon it was a better model.
still i'm finding it hard to even find an mx5 for under 10k, besides a few ragged '90 models.
i've been told this one is in perfect condition (yet to be seen), serviced regularly etc.
so for 9k, i think it's a bargain if all checks out ok.
The 1st series is supposed to be the most fun to drive. I have driven the 98 model and that has more power and is a smoother engine. Id probably check the top to see any tears and what not. Check the bolts to see nothing has been removed before (they leave marks if they ahve been removed). Do the usual oil check, water etc. Test for black smoke - rev it to around 3500 or 4 - and keep it there, then hit the gas and let go real quick - that will show if any black smoke is coming out.
Lastly, mechanical inspection - since this is not a turbo normal mechanical inspection should be ok i think....
3500 - 4000rpm ???
that seems pretty high to be revving in neutral. are u sure emsta?
Awesome handling on these. My dream is to get a cheap one imported for race and whack a soarer V8 in the front end. ctjet wouldn't ever catch me :rofl:
Ignore everyone else and just enjoy a brief nip out for fun.
But the roofs are the only problem i know of.
How sweet is the new folding lid MX-5???
Oh yeah, agree with Emsta. I'm doing the head on one right now for a mate off a 1.8 MX-5. You can safely go to redline in neutral. Also look for blue smoke on backoff.
My dream is to get a cheap one imported for race and whack a soarer V8 in the front end. ctjet wouldn't ever catch me :)
:rofl:
weight distribution 70/30 might be a problem in the MX with the mighty V8 tho... and munkeh if you see blue or black smoke come out of any car you should walk away
I think I can save you a lot of hassle. A friend of mine has one that he imported and has been used as a second car to his two skylines. It's in awesome condition with nice rims, good paint work and he replaced the soft top since he's had it. from memory it comes with a hard top too which is pretty cool. The best part is he is a mechanic and a very good one. He owns Grey Imports in annandale. The car has not been advertised yet, but i know he is keen to sell as he offered it to me. I would definately give him a ring. 9519 5150. I would have bought it to use as a second car (well 3rd car) but my GF cannot drive manual. price is very reasonable too.
LOL Richard, you are so quick. I just finished sending a pm letting him know about this car also.
Cheers
Jo
what year? how much? i'm about to go see this one now, but will keep in mind. thanks
EDIT: nevermind, have details in PM. cheers.
Edited by Munkyb0y
3500 - 4000rpm ???
I did that with all the r33's to test for black smoke - they all were fine :). And I also have done that with my 82 civic - which sadly I must say gives out a lot of black smoke :rofl:
edit - yeah if there is any blue or black smoke - say that there is another car you want to check out as well and that you will let the guy know - then just run like hell....
Edited by emsta2003
Cheers
Jo
lol, you have to be quick to beat me Jo! :rofl:
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
