I have 5 plus years of experience and I am exceptionally good at my job. I am a IT engineer and for the last 3 years, I was making a decent amount of money. Now I am jobless.
I have never had a dearth of offers and as a result I had a wonderful career right from the age of 18. Now, at 23 years I am finding myself side lines by younger graduates with good BULLSHIT skills. It seems that the world today prefers only graduates with BS; they do not seem to value experience and expertise anymore. I have 5 years of experience and some great references, but no one is really bothered about it. I do not have the "BS skills" – with my experience, there is nothing that a new grad can do that I cannot do ten times better.
But how can I prove my point. Thanks to my Skyline in the last three years my savings have been eroded to almost nothing.
This is the first time I feel the importance of a post graduate degree. For 5 years it never came to my mind because my skills were so highly appreciated. Now I can hardly make to the interview table, and then I am rejected like trash.
I have tried all my resources, asked friends for help, family, relatives, all. In my last interview, there were a couple of guys who were up to no good, started making trouble in my neighbourhood I got in one little fight and my mom got scared and said you're moving with your auntie and uncle in bel-air. I whistled for a cab and when it came near the Licensplate said fresh and had dice in the mirror, If anything I could say that this cab was rare But I thought nah forget it, yo home to bel-air. I pulled up to a house about seven or eight and I yelled to the cabby yo, home smell you later. Looked at my kingdom I was finally there to sit on my throne as the prince of bel-air.
https://www.sau.com.au/forums/topic/135388-wink-got-owned/
  • Replies 48
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
