Hey guys,i changed my own spark plugs today for the 1st time,and apart from the fact the car is still Running:).....im not so happy.
I previously had some ngk's gapped to .55mm and my car was running fine at 10psi..,this was done by a workshop, and they fixed my missing issue.
But i decided to change as i thought .55mm was quite low for a car with jst pod/zorst and fmic running 10psi.
So i went and brought some ngk's that alot of ppl on this forum use (dont know the gap rating, but the outlet store said they are close to 0.8mm)
I installed using a guide posted on this forum (which greatly helped), and after all had been done, i took the car for a spin, and anything over 5500rpm would make the car pop like mad!
so im thinking the plugs arent gapped properly?
few things id like to ask
1) how good are the spark plug gap gauges(wire ones)
2) when removing sparkies should i spray compressed air around the area and be done with it?
3) Do these spark plugs have to be torqued down?, ive been using a rathchet to tighten firmly.....is this advised?
thanks in advise, i may have to do this all over again in the wekend, for now ill go back to stock boost:)
  • Replies 41
Hey i think they just gapped them to .55mm to be sure that it wont ping/pop anymore, as it was 1.1mm beforehand.....so i have nevertried .8mm.....and it seems that the ones in my car at present may not quite be 0.8mm(i never had any tools to measue:(
one other question though.....whats the best way to clean the area arounf the spark plugs???using something like Dust off (can of compressed air thats used most often for cleaning electrical components keyboards etc....)
i'll be having another go soon.
I was reading some other threads,and it seems that i should have cleaned the area before even removing the plugs(incase of anything going into the chamber).......i didnt do this....could this be a cause of the problem?i hope i havent done something to my engine.
leave the plugs in when cleaning the area!
as mad082 said, if they were gapped to 0.55, think there will be a coil pack problem or something if its missing with 1.1 or 0.08!
been there and had the same issue
Just in case you doubt the first two recommendations...
If your car is missing with 0.8mm gap then it is time to replace you coil packs. If you do decide to replace them, you will be much better off buying Splitfire coil packs.
So double check your gapping, just take the plugs to your local mechanic, and make an educated decision.
whoa, hold up the love boat, if you just popped your spark plug changing cherry, i would go back and remove the plugs, there is a very real chance you may have cracked a plug. they can be quite delicate. also double check the gaps.
i have experienced this with even a well known "performance" shop (bob romano's) having cracked a plug in my 25 for me to discover. it's not hard to do even if you are experienced!!!
i never heard of that. i dropped 2 of mine before i put them in. 10,000k's at boost between 12 and 14psi and no problems yet. i know they can be broken, but i wouldn't say they are delicate.
Edited by mad082
how can you tell if youve cracked a plug, and how would it happen?overtightening?
also it seems everyone thinks my car is missing at 0.8mm gap, i dnt actually know the gapping on my pressent plugs, and the last ones i had went from 1.1mm down to .55mm, we never tried .8 back then.
So i think my coils maybe ok
if it is missing at 0.8mm gap then there is a spark issue, and you aren't running enough boost to have issues with a 0.8mm gap unless the coil packs are lazy. 0.55mm gap is extremely small! much too small for low boost.
Spitfires are a direct replacement..
What car/engine? I'm assuming RB25 as your listing 10 psi as a mod.
Do you have any aftermarket engine management?
Mine had the same issues with .8mm plug and the same mods.
Coilpacks were repaired, made a difference, but still mild pop. Really bad on cold nights.
Got the car tuned with some aftermarket managment, works a treat! More power too. Never popped again. On researching it I found that the issue was just the mixture was getting to rich to ignite.
Alot of people on here have replaced the coil packs and the problem goes, however, alot of people have also replaced coils and the issue had not go away as it was something else, like rich mixture...
they should not be too tight. especially with an alloy head it's very easy to stuff the head by overtightening. there are torque specs in the shop manaul and it's very low.
you should have checked all the gaps before installing them. also, no one has asked yet. what heat range are they?
always clean around the plugs BEFORE you remove them as the whole point of this is to stop sh1t dropping down into your engine.
cheers, ill confirm they are gapped right and let you guys know.
Btw no one ever told me how tight the sparkies should be tightened?
According to the NGK website, they should be torqued to around 20 lb/ft (which isn't actually all that much). And they should be installed into a COLD engine (well, torqued down when the engine is cold).
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
