i put 6*9's in my rear because i didnt have the cash at the time to buy different speakers. However I am very impressed/satisfied with the sound they produce.
"cutting the parcel shelf is illegal dont do it",....hahahah so are most of the performance mods.hahahahaha
if your are going to cut your shelf, be warned its a bit of a job have plenty of band aids on hand ready.
https://www.sau.com.au/forums/topic/13586-6x9s-in-33gtst/#findComment-290816
6x9's fit quite well in the rear if u put em at the angle like elbee said, the rear parcel shelf is easy to get out, the lack of space in the back seat however gets annoying, make sure u have like a fan cos it gets HOT and sweaty. zRemove the back seat (easy to do) the just unclip the rear shelf. too easy
https://www.sau.com.au/forums/topic/13586-6x9s-in-33gtst/#findComment-302585
  • 1 month later...
If you space them, or make a new shelf, angle them at 45 degrees, you will have know problem. Or if you are like me and are too lazy get someone to do it for you.
Here is mine. I am happy with the result. Pics can be found here.
http://www.skylinesaustralia.com/forums/sh...&threadid=15486
https://www.sau.com.au/forums/topic/13586-6x9s-in-33gtst/#findComment-365611
It was a tad expensive, cost me $250, but considering it took the pros 6hrs to make with all the right tools/materials at their finger tips, I think it was worth it. I could never have made something that nice anyway, no matter how much time I spent on it. And the best thing is it looks so neat and factory like that know one would suspect what in their.
The only draw back was the strong resin smell I had to endure for a week, just had to leave the windows down in the garage to let it air out.
That price was bargained too btw as I am a repeat customer!
https://www.sau.com.au/forums/topic/13586-6x9s-in-33gtst/#findComment-366067
  • 4 weeks later...
jimbo2000 don't listen to them dude 6x9's do fit in the back all you have to do is make a new parcel shelf with 14mm spacers on a6-8mm shelf and positon your holes over the existing ones which originally fit a slightly smaller speaker did them in a mates 33 no sweat . just make the shelf itself out of 6mm and then the risers out of 12-18mm mdf whatevers thickness gives you clearance over the battery and then smooth out the spacer edges with bog cover in grey carpet easy
https://www.sau.com.au/forums/topic/13586-6x9s-in-33gtst/#findComment-414284
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
