I used a call out service, Dent Craft. They rolled my front and rear guards on my R33, did a VERY good job. I took my car to him and it was $50 a corner I think. Unsure what it would be for call out.
0409 906 593 Stuart is his name, I think he is based in Ardross, which is near Booragoon.
https://www.sau.com.au/forums/topic/135953-guard-rolling/#findComment-2535759
cheers for the info guys...
V&B body repairs in osb park are gonna sort me out
top guys there!
was quoted $50 a corner and the dude there also said he can fit the wheels and adjust the coilover height if need be!
all i have to do is get a wheel alignment done at a tyre shop.
as far as paint cracking goes he said all care taken but he cant guarentee it wont happen
Edited by iz32
https://www.sau.com.au/forums/topic/135953-guard-rolling/#findComment-2544574
ah i forgot to add...
i got bored tonite and decided to remove the plastic inner guards as i was told they'd have to do to roll the guards... anyways i noticed on both sides that there are grommet holes with wires/vac hoses/exhaust sensor wire etc.. passing thru them.
do i need to refit the rear 3rd of the plastic guards? to stop water getting into places it shouldnt or is it fine to leave them off altogether??
they come in 3 pieces and are stapled together.
any experiences?
https://www.sau.com.au/forums/topic/135953-guard-rolling/#findComment-2544577
Yep Dent Craft got my vote as well, got the guards rolled on the lude for 50 a corner top job.
https://www.sau.com.au/forums/topic/135953-guard-rolling/#findComment-2545479
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
