  • Replies 176
Posted Images
well i've been slack...
but here are pics of the car - etc :banana:
new cradle/rear suspension locking washers added
S14 steering rack fitted with rack end spacers and custom line
steering rack urethane coupling bushes added
rear cradle has been moved onto an angle for grip with drift pinapples (alloy in the rest)
spring rates changed to 8kg front 6kg rear.
enjoy :teehee:
Edited by huddy
  • 1 month later...
we ran out of time - we had it on the dyno and had to add fuel everywhere - but initially found differences of 30 odd rwkw lower because of it wheelspinning on the dyno - with almost 100L water in boot + 2 people, plus 1 person either side holding chocks on front wheels it still tried to jump off the dyno (twice)... but ended up netting same result of 262 with cam gears set at 0.
due to adding fuel in throughout the tune - gives me the impression it's making more power - just cant get it to the rollers.
Once we get more time / get around to it - will get it all strapped in properly and spend the time tuning it with adjustments to cam gears.
on another note - made some more changes. to some things
- new steering rack boots (checked s14 rack is not leaking yay)
- tension bar to rear cradle / toe arms
- locking washers all fited
- cradle angle changed by adding pinapples
- diff angle changed
cheers
-Matt
  • 1 month later...
it's been a while... so just a quick update - a few new bits have been ordered / fitted... will post pics when they're done.
I have a bar welded in between castor rod brackets.
Carbon Fibre GT wing fitted.
Supernow rack spacer - on it's way
326 power modified knuckles - currently being done
bolt on flares - on their way
bolt on spacers x4 - yet to be fitted
Also had a little bit of a bingle at mallala, but all fixed and painted, it was just fibreglass mainly.
G1 rd 2 is this weekend so should have some good action shots :D
Hey Matt,
Just saw your pics of the black 99 stag with the R34 GTR wheels nice car. Is it a RS or a RS4? Auto or Man?
I only ask cause i have the same car with the std wheels and have been looking into getting a set of the same wheels for it. Any problems with skrubbing? What is your Centre of wheel to guard height?
Does it toe the car ok? I have been thinking how they would go towing a larger car, I have a R33 GTST track car that i have to toe around with my dads 4WD.
Sorry for the 20 questions.
PS: Nice drifter.
Cheers,
Ryan
  • 1 month later...
wheels are 18x9 +24 and 18 x 10 + 22 ( i think that is correct )
i'm running 30mm bolt on spacers front/rear now, but this is to accommodate my Bolt on flares that i'm about to put on...
****further update****
326 power knuckles
NISMO lower control arms (increased track)
KTS tie rod ends
S14 tie rods
SUPERNOW rack end spacer
URAS tie rod spacer
VELO GP90 seats x 2
BLITZ SPEC R boost controller
NARDI deep corn 330mm wheel with red stitch
Bolt on flares all round
will post pics in the next couple of weeks when it's all sorted. :nyaanyaa:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
