Gday, well Im doing to do a transmission swap in my turbo auto R33 because auto is teh sucks for throttle control.
Seeing as RB25 gearboxes are going for 1500 plus lately I was considering using an RB20 box. I was wondering if this was possible, ie a straight bolt in or would I have to stuff around to make it fit? Keep in mind I'm not building a power monster, ie im only aiming for 250-300rwhp MAX once I'm done with the car. I'm building it for response, not for massive straight line go.
Im just not sure if the RB20 box would cope with the increased torque. Also, I'm very sympathetic to my drivetrain, there will be no flatshifting or 7k launches etc.
https://www.sau.com.au/forums/topic/136560-rb20-gearbox-in-an-r33-gts-t/
Thanks Munna1 yeah I understand that its torque that kills em..
I've heard of people using them for VL turbos, with varying success. What would an average 250rwhp car be putting out in terms of torque? Keep in mind this is probably running stock turbo or a highflow item.
So it would bolt up, but require a custom driveshaft?
Anyone running big torque/power through a RB20 box?
;) I would not bother dude! I just changed mine to a rb25det box, cos rb20det boxes dont handle much!
I know some people arnt made of money, whatever your cash flow is? Save your coin, and get a rb25 box!
Tailshaft slipyoke on a rb20det box is heaps smaller than an rb25 one :wave: So you will need tailshaft mods!
I want to change mine to auto cos i am sick to death of manual boxes! Me and them dont mix! ;)
People think manuals are quicker,but i think you have to be a perfect driver to make a difference shift times etc.. :)
In theory it shouldn't cope as Nissan themselves saw fit not to use it behind the RB25 but many people have used them with success.
Will all depend on how you drive it though and what condition the box is in when you get it.
R31NISMOID had a 20 box behind his RB25 (over 300rwhp) and it lasted a long time.
Also plenty Of R31 guys turbo the NA engine (3 litres = more torque than 25) and keep the standard box which is near on identical to a 20 and make them last, although some smash them every 6 months which again comes down to driving style, clutch choice and tyre choice.
If your car is still running with the auto I would just save a little longer and get the Rb25 item.
The 20 box is cheaper, yes, but you will need custom tail shaft, custom/modified gearbox mount and sort out the speed sender. Obviously with 33 box it will all be factory parts you can source s/hand.
play R 32 (i think thats his user name on the forums) is running in his R32 GTST with a RB26 conversion with a rb20 gearbox at over 300rwhp
since its an auto your going to need a custom tailshaft, centre console, clutch master/slave cylinders n shit done, if your not a bastard on your gearbox then a rb20 box would hold up fine
btw what is the price difference between a rb20 and rb25 box coz 1500 sounds cheap as last year when i enquired i was gettin quotes of 2-3k
1 more thing, C-red does a drive in drive out deal on this for $3800 using a 25 box, takes approx 4 days i THINK (quotes from last year so might be a outta date)
Edited by R32 Driver
Two things to look at here. The condition of the box, you would expect an RB25 box to be in better condition as in most cases they are newer, and they are stronger. That and where your rb20 box is coming from, they might have done the same thing you are thinking of...
The other is resale (might not be thinking of it now but you should), I can tell you now if you car was identical to another price, colour extras etc, but yours had the rb20 box and the other was rb25... I wouldnt be buying your car.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
