  • Replies 43
schmiko! can't believe you won with stock rims, I guess its a testiment to how good the bodywork is then if they can overlook wheels in the process considering how many show cars have crazy expensive rims on them while in shows.
have you considered trying to get sponsorship from a wheel shop or something?
https://www.sau.com.au/forums/topic/136702-got-wax/page/2/#findComment-2549536
I just borrowed one of those MOTHER hand buffing machine - FARKING BRILLIANT.
Did the GTR and the Liberty over the long weekend - and what a great result.
I will be buying one of these gems this week/next week as they do making a shit job quite simple and easy.
Cant recommend them highly enough. Seriously one of the must haves if your serious about keeping your car tip top.
Daniel
Ahh Mothers buffing machine, 70% is done by hand
https://www.sau.com.au/forums/topic/136702-got-wax/page/2/#findComment-2549628
O there about 160$, Pads are aboput 16$ to replace. If your doing the mothers propertly use the three steps.
1. Wax Cleaner/Removes Oxidation
2. Sealer and Glaze
3. Pure Carnaubra Waz
4. Showtime instant Detailer
Go to bunnings and buy 3x 3 packs of microfiber cloths.
Use the 2 cloths for each of the coats, one to apply one to remove! Keep turning your cloth around also. I cant stress this enough using different cloths for each stage.
Allow the wax to dry on the surface before removing, it has to marry to the surface. Other wise you are wasting your time and money. Dont be shy with the last coat of wax wipe it on so theres a lovley covering. Theres really no need to rub it in just so it coveres all the surface.
Be patient allow a good day for this. Always make sure your car is washed
before you do this!
https://www.sau.com.au/forums/topic/136702-got-wax/page/2/#findComment-2549700
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
