Hi,
When should you use a turbo timer?
I have a turbo timer installed (standard car running standard boost) and i only use it when i give the car a bit of a thrashing. Normal driving i dont bother with turbo timer.
is this wise? or should i always use it?
cheers
https://www.sau.com.au/forums/topic/136806-turbo-timer/
you only need to use it when you've been on boost just before you're turning the car off.
If you drive normally and stay off boost when you're getting close to where you're going, you dont need to use the TT as the turbo hasn't been doing anything
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2543148
TTs are after-market gadgets. If Nissan had wanted you to use one, they would have installed them as standard items.
TTs are generally for idiots who can't control their right foot during the last km of any trip, and are then too impatient to wait with the car for a minute while the turbo cools down a bit.
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2543233
I dont have a TT...
...I just take it easy as im approaching my destination, and usually wait about 15-20 odd seconds (Usually spent closing windows, sunroof, side mirrors) before switching it off....but i never let it sitting idle as you'll end up trapping a bit more heat due to no/less airflow.
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2544698
exactly. letting it sit on the spot idling creates heat soak, which can raise the temp. if i fan it around close to home i usually just idle around the block to let it cool down.
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2544858
I dont have a TT...
Ha? Can you elaborate? I live near a big hill and when I climb it my car usually sits around 2000-2500 RPM. So the turbo is working slightly and needs bit of cooling (20-50 secs) so I just idel in my drive way If i have time or walk off with TT on.
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2544949
I dont think anyone is saying a TT is harmfull champ!
Sir-D,
Im not sure what you want me to elaborate on? ...basically all im saying in my post is to take it easy as u approach ur destination and you wont really need a turbo timer.
And my personal opinion is that if you think a TT is gonna save ya then think again.
Thrashing your car then coming to a complete stop and leaving it on TT will NOT cool down the rest of your car like transmission etc...
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2544976
TTs are a bit of a wank, all that's needed is some common sense either drive gently and give it 10 seconds to idle before turning off or let it idle for 30-60 seconds and be done with it. Did this with my last car and never had a problem.
I do have a TT integrated with the alarm on my current car, this lets me be lazy and take the key out, get my stuff etc and then as I walk away I override the TT and turn the motor off then arm the alarm. Could count the number of times I've let it run the full 90 seconds (fixed) on one hand.
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2545093
Sir-D,
But isnt that related to any car, turbo or not as far as cooling the tranny etc goes?
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2545444
From Wikipedia, the free encyclopedia
Jump to: navigation, search
A turbo timer is a device designed to keep an automotive engine running for a pre-specified period of time in order to automatically execute the cool-down period required to prevent premature turbo wear and failure. After a period of driving when a turbocharger has been working hard, it is important to let the engine run at idle speed for a period of time, allowing the compressor assembly to run down in speed and cool from the lower gas temperatures in both the exhaust and intake tracts. At the same time the lubricating oil from the engine is able to circulate properly so the turbine won't burn the lubricating oil that would otherwise be trapped within the charger with the turbine rotating at high speed.
http://en.wikipedia.org/wiki/Turbo_timer
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2549478
Ive seen on some TT's it says suitable for Turbo charged Vehicles and NA vehicles. I always go easy a few mins before reaching destination and give it a few secs when i pull up.
The shafts on most turbochargers spin in excess of 50,000 RPM and generate lots of heat. To keep your turbocharger's heat under control, most are cooled by circulating oil or water (coolant) around the shaft. The turbocharger's shaft is free to rotate at will and there is no way to stop the shaft from spinning after shutting the engine off. To dissipate and stabilze the heat in the turbocharger, most manufacturers recommend that a car be idled for a period of time after moderate to hard driving to allow the oil/water to take heat out of the turbocharger.
Failure to reduce the temperature of the turbo could result in the oil around the shaft "coking". Coking is basically the baking of oil, turning it into a hard substance that could plug your oil lines and cause oil "starvation", preventing proper cooling of your turbocharger and reducing it's operating lifespan.
Edited by 95SKY
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2549516
If you take it easy just before you reach your destination.. a turbo timer isnt needed..
anyone who thinks they can drive hard then shut off their car immediately is stupid.. turbo timer or not
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2549844
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
