Hi Everyone!
How are you all? It has been a while since I was last on here due to work and other commitments.
I have a question regarding the knock indicator on the Apexi Power FC. Is it possible to change from the bar graph to the numerical frequency? I usually have 8 gauges showing at any one time and when I press the up arrow a number comes up beside the Knock indicator, which has been as high as 28 but then it seems as though the hand controller intermitently freezes. Do I have a problem, Are the knock readings to high? Please help!
Sincerely
Richard
https://www.sau.com.au/forums/topic/136827-knock-indication-on-apexi-power-fc/
28 is fine, anything over 60 it fringey, anything over 100 needs to be looked at very soon. If it is always over 100 your in trouble, but generally you only see peaks when putting the motor under load ie going up a steep hill in 5th and then trying to give it the boot!!!
You can mitigate knock by using a trailing throttle ie when your going up the steep hill, slowly ease off on the accelerator ie start at say 100km/h at the bottom and then be doing say 80km/h by the top of the hill. OR you could just select a lower gear and not put the car under load in the first place.
The pfc graph is live,and flickers with the knock reading, the number under it is a peak hold number ie the highest reading experienced is shown. You can reset it to zero on the fly by pressing the right arrow. It also resets every time you turn off the ignition.
I've set my PFC up so it only displays 4 readings (Knock, Water Temp, RPM and Speed). I have the up arrow pressed so it shows the highest readings, plus the numbers are quite large for you to see with the live readouts.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
