Hello,
Im a bit of a learner when it comes to turbos.
Now i've had my r32 gts-t for about 10months, the previous owner in japan has fitted a z32 AFM, adjustable fuel pressure regulator, the injectors im fairly sure are GT-R ones as there is a resistor pack, and they only read about 3 ohams. The ecu looks stock, but, things like the speed limitor have been removed, so i assume its been played with also. The car also has a FMIC
Now, Im not quite sure how high i should turn the boost up, at the moment im running it fairly stock, as im frightened of turbo damage if i turn it up to much. Today i removed the dump pipe to have a look at the wheel, now, i don't have a clue what i was looking at so i took a picture in the hope that someone on here would be able to tell me if its ceramic or steel. The acual wheel is not all that big so i'm assuming its pretty much the stock unit.....
Sorry about the poor image quality.
Thanks
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/
whiter31gxe,
Have you had it on the dyno for a power run to see if its pinging and what the afr's are like?
Do hit the dyno before winding up boost or possibly wind the boost up on the dyno. At least you can see what its doing. Especially as the ecu has clearly been fiddled with.
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2544390
Thanks for the replys.
I have not had it on a dyno yet. I forgot the mention that i do have a SAFC II hocked up to the system, still have not had it tuned yet, been holding out till I work out what i was going to do turbo wise, but, it does not register any knocking.
Also does anyone have a recommendation for a dyno to use on the mid north coast?
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2544699
which also has a ceramic wheel?
yes, but you can run around 14psi comfortably on the RB20 with 25 turbo.
ITs been well covered the gains from putting an RB25 turbo on
http://www.skylinesaustralia.com/forums/in...howtopic=103095
http://www.skylinesaustralia.com/forums/in...showtopic=66556
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2544713
Hello,
Thanks
dude,
that doesn't look like the standard rb20 turbo.
if you look closely it actually looks like the 9-blade turbine which is found in the HKS 2530.
you might want to check the id-plate on the centre core.
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2544779
As people have said:
1) Get on a dyno to check the AFRs. That exhaust wheel looks pretty good to my eyes (in terms of colour) but if you fiddle the boost that can change so don't change the boost unless you're on the dyno.
2) RB25 turbo is a good upgrade on an RB20, I went with the S2 turbo on my last car and the power delivery was fine. But check the turbo you've got on there as it sounds like you could have an aftermarket one already :D
3) RB25 turbos - S1 has a steel compressor wheel and ceramic turbine wheel. S2 has a nylon compressor wheel and a ceramic turbine wheel. The R34 turbos have a plastic (!!!) compressor wheel and ceramic turbine wheel. I picked an R33 S2 turbo as nylon is lighter than steel so should spool a bit better on an RB20.
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2545058
dude,
The RB20 turbo that came off mine has 9 blades. Looks identical to mine.
The R33 S2 and R34 Compressor wheels are made of the same plastic type material. Its not plastic just looks like black plastic. :D
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2545077
2) RB25 turbo is a good upgrade on an RB20, I went with the S2 turbo on my last car and the power delivery was fine. But check the turbo you've got on there as it sounds like you could have an aftermarket one already :(
why so "!!!" over plastic compressor wheels? - nylon is a polymer also - kevlar is a polymer and its stronger than steel and used as bullet proofing - "plastics" dont all necessarily have the same properties of a shopping bag.
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2545339
i already knew about the "r33 turbo on an rb20 running 14psi is fine" thing, but for my knowledge, why is an r33 turbo able to run 14psi on an RB20 but only really good for a daily 10psi on an rb25?
is it the extra displacement has a lot more heat, which causes the wheel failure?
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2546401
Airflow... The RB25 head flows air in and out of the pots easier.
14psi on an rb20 makes ~190rwkw, ~11psi on an rb25 makes ~190rwkw. They will both be spinning at a similiar RPM and pushing similiar air. Once you start pushing a turbo past its airflow capability it begins to push hotter and hotter air that is more prone to detonation, higher egt's (the real killer), greater turbine back pressure etc.
No one apart from garrett and the likes really knows but thats basically it.
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2546492
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
