32vspecII Posted October 2, 2006 Share Posted October 2, 2006 hi ive read the rb26 turbo upgrade section and ive settled on 1 of these turbos i really want a quickish street car with the occasional motorsport/drag event . say 300awkw . more is good if its not at the expensive of lots of lag . im looking for something drivable . obviously the -7 with .42 comp should be best but a few people have mentioned it comes on boost very severely with the -5 having a much smoother progressive power delivery which might be better for a daily driver if anyone could shed any light on exactly when and how these turbos would come on boost it would be appreciated. Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/ Share on other sites More sharing options...
ferni Posted October 2, 2006 Share Posted October 2, 2006 I always get mixed up between the 3 trims, -10, -7 and -5. One of them is like the HKS GTSS, and will be the one you are after, will get you around 300kw at the wheels, very responsive. the next one up is a bit smaller than the 2530's, and will get you around 340kw at the wheels, still very drivable, probbaly a touch more lag if you can call it that. the next one up i don't know much about. A smaller turbo normally comes on boost more progressively and smoother, doesn't feel as fast because it doesn't give you as much of a kick in the back. Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-2547450 Share on other sites More sharing options...
Ronin 09 Posted October 2, 2006 Share Posted October 2, 2006 Correct me if I'm wrong, but the -5 is the 2530 size and -7 is the GT-SS size Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-2547553 Share on other sites More sharing options...
32vspecII Posted October 2, 2006 Author Share Posted October 2, 2006 GT2860R Turbo spec's (please choose -5 or -7) GT2860 Turbine (-5) (Similar to the HKS GT2530) : -Wheel: 53.85mm w/ 76 trim -Housing: .64 or 0.86 ar (with wastegate divider) GT28 Compressor: -Wheel: 47.2mm inducer, 60mm exducer w/ 62 trim -Housing: .60 ar ______________________________________________________ GT2860 Turbine (-7 similar to the R34 Nismo N1 Spec or HKS GTSS): -Wheel: 53.85mm w/ 62 trim -Housing: .64 (with wastegate divider) GT28 Compressor: -Wheel: 44.5mm inducer, 60mm w/ 55 trim -Housing: .42 ar (not much smaller then 0.60 AR on the -5) also i belive things like exhaust manifolds and cam gears will help make boost earlier ? when would these turbos actually make full boost ? Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-2547589 Share on other sites More sharing options...
700HP-GTR33 Posted October 2, 2006 Share Posted October 2, 2006 hello, -5's with Poncams,Dumps and Computer will get you your figures you are after. Full boost on mine, without poncams come in at 4500RPM. You wont get those figures with the ss(-9 )or n1(-7) unless you do some engine work. The gt-rs(-10)_ for Rb26 will have to much lag for day to day driving. Hope I have been of some help. Cheers Tekin Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-2547600 Share on other sites More sharing options...
32vspecII Posted October 3, 2006 Author Share Posted October 3, 2006 will cams make it come on boost later but have more top end ? or will the low end be the same ? Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-2549241 Share on other sites More sharing options...
700HP-GTR33 Posted October 3, 2006 Share Posted October 3, 2006 will cams make it come on boost later but have more top end ? or will the low end be the same ? With the Poncams 260Degree with 9.15mm Lift responce is better through the low,mid and high ranges. Boost comes in earlier around 4300RPM with the set up I have mentioned. Other cams give you high end power figures only..Some mods to spring,retainers and even higher head gasket are needed with higher lift cams.This is not cheap, check out some pricing and you will see. These cams are only good for top end power delivery,mid range is slightly higher than factory units Poncams also work with standard computer,,,so in Melbourne if you get busted with a Powerfc, there is no problem installing your old computer back.Poncams are a bolt on and off you go unit. But getting back to the original topic.............if you are just after some useable power gains. Buy the -7 or -9 Turbo's get some dumps, throw in the Poncams and you can be expecting to get 280AW kw's with a good tune(even a standard computer)at 1.3Bar. If after all this you want a little more power, then the N1's or ss Turbo's will not take you there. (Unless you spend a bucket-load on the engine.) So the choice for me was obvious, I bought the -5's. These will see me to 310AWkw's Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-2549594 Share on other sites More sharing options...
700HP-GTR33 Posted October 3, 2006 Share Posted October 3, 2006 Correct me if I'm wrong, but the -5 is the 2530 size and -7 is the GT-SS size Yeah your wrong. This is why I have a Warn,10% under my name. Tuneagent listed them as you have stated Ronin 09. How do you get that warning off? When do I get my 12 points back Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-2549635 Share on other sites More sharing options...
png godzilla Posted October 3, 2006 Share Posted October 3, 2006 Arkon, i have the -10's fitted to my R32 GTR & got the HKS actuators as the -10's don't come with actuators. i have plenty of bolt on mods but no cams or anything as yet. i got these turbo's because i have another engine & can put up with the Lag untill i put stage 2 in. basically the -10 won't hit more than 0.5bar untill 5000 RPM, but when they come on, boy do they come on, 1.2, 1.3, whatever the're set to in an instant!! I like em, big plans ahead!! here's the mods at present with the -10's (laggy as hell) Tommei S/S Extractors Twin Garrett GT2860R (707160-10)0.6/0.64A/R (450hp models) HKS Actuators HKS Dump Pipes HKS Front Pipe Cat removed & 3” full back Splitfire coils NGK HITOP Iridium Plugs APEXI FC & Hand Controller 600x300x125 FMIC (cut the front out to match the IC/8” Ducted air tubes to POD filters) APEXI POD intake NISMO FUEL PUMP Nismo Adjustable Fuel Pressure Regulator SARD 720cc injectors (not yet installed) Water/Methanol Injection Wide band A/F meter HKS Twin Plate Clutch PAR Racing Products Gear Set, straight cut 1st, 2nd & 3rd Helical 4th & 5th, Beefed up Synchro shift. Greaddy Prfec B Spec II Boost controller Apexi RSM Speed Limiter cut & G Sensor Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-2551554 Share on other sites More sharing options...
bnr#@ Posted October 4, 2006 Share Posted October 4, 2006 (edited) Arkon, i have the -10's fitted to my R32 GTR & got the HKS actuators as the -10's don't come with actuators. i have plenty of bolt on mods but no cams or anything as yet. i got these turbo's because i have another engine & can put up with the Lag untill i put stage 2 in. basically the -10 won't hit more than 0.5bar untill 5000 RPM, but when they come on, boy do they come on, 1.2, 1.3, whatever the're set to in an instant!! I like em, big plans ahead!! here's the mods at present with the -10's (laggy as hell) Tommei S/S Extractors Twin Garrett GT2860R (707160-10)0.6/0.64A/R (450hp models) HKS Actuators HKS Dump Pipes HKS Front Pipe Cat removed & 3” full back Splitfire coils NGK HITOP Iridium Plugs APEXI FC & Hand Controller 600x300x125 FMIC (cut the front out to match the IC/8” Ducted air tubes to POD filters) APEXI POD intake NISMO FUEL PUMP Nismo Adjustable Fuel Pressure Regulator SARD 720cc injectors (not yet installed) Water/Methanol Injection Wide band A/F meter HKS Twin Plate Clutch PAR Racing Products Gear Set, straight cut 1st, 2nd & 3rd Helical 4th & 5th, Beefed up Synchro shift. Greaddy Prfec B Spec II Boost controller Apexi RSM Speed Limiter cut & G Sensor edited Edited October 4, 2006 by bnr#@ Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-2553200 Share on other sites More sharing options...
joeleo87 Posted October 1, 2008 Share Posted October 1, 2008 Im sorry to pull up an old thread but.... im in the process of buying a set of either -5 or -7s (for some reason they are the same price??? so it warrants some research) basically im buying the new turbos because Ive just joined the "ZOMG there goes my rear turbo" club. so im running stk everything but a cat back exhaust. eventually ill get another ECU, dumps, front pipe and search for about 300kws. my question is, what turbos will be more responsive with minimum mods? -5 -7? also what will suit my 300kw application better? cheers Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-4168449 Share on other sites More sharing options...
TiTAN Posted October 1, 2008 Share Posted October 1, 2008 GT2860 -7 Turbine (similar to the R34 Nismo N1 Spec or HKS GTSS) will get you 300kw and be responsive. the -5's are a bigger turbo and will as such be more laggy. Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-4168667 Share on other sites More sharing options...
R31Nismoid Posted October 1, 2008 Share Posted October 1, 2008 -7's... the same answer for everyone after 300-330rwkw Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-4168692 Share on other sites More sharing options...
rev210 Posted October 1, 2008 Share Posted October 1, 2008 -9's are also now an option. They are the closest match to the GT-SS. The compressor map is very nice indeed. Has the very close efficiency island at the 30+ airflow to the -5's , where the -7's are going to be pumping that sort of air with alot more heat. They appear to be a newer style? With the best of both worlds for those wanting to make the airflow over 250rwkw + with less effort than the -7's. Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-4168939 Share on other sites More sharing options...
some_cs_student Posted October 2, 2008 Share Posted October 2, 2008 So, just commenting on the above post, the -9's are more responsive than a -7 but less overall power? Any idea how much power is normal for a -9? Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-4171447 Share on other sites More sharing options...
GTR1993 Posted October 2, 2008 Share Posted October 2, 2008 -9's are also now an option. They are the closest match to the GT-SS. The compressor map is very nice indeed. Has the very close efficiency island at the 30+ airflow to the -5's , where the -7's are going to be pumping that sort of air with alot more heat. They appear to be a newer style? With the best of both worlds for those wanting to make the airflow over 250rwkw + with less effort than the -7's. With these -9s ( i have searched and have seen disco talking about them alot) and the HKS GT SS turbos will they reach 350 rwkw? I'm trying to build an awesome responsive std stroke 26, paying particular attention to getting the exhaust and inlet flow in the head right up (mostly exhaust as they are quite poor standard). My aim is 350 rwkw and i want to be able to make this on pump all day. I have all the parts just not the turbos and oversized valves at the moment. Cheers Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-4171616 Share on other sites More sharing options...
rev210 Posted October 2, 2008 Share Posted October 2, 2008 The -9's will get the 350rwkw is my bet. Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-4171762 Share on other sites More sharing options...
Tomek Posted October 2, 2008 Share Posted October 2, 2008 -7's are the most responsive out of them models. Garrett equivalent of the HKS GT-SS turbine, good for up to 350rwkw. Speaking of which I got a set for sale, in spanking condition Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-4172007 Share on other sites More sharing options...
GTR1993 Posted October 2, 2008 Share Posted October 2, 2008 -7's are the most responsive out of them models. Garrett equivalent of the HKS GT-SS turbine, good for up to 350rwkw. Speaking of which I got a set for sale, in spanking condition the garrett -9 is actually the HKS GT SS equivalent, its the actual same turbo as the gt ss, the garrett and hks cartridge numbers are actually the same. Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-4172134 Share on other sites More sharing options...
Bakes Posted October 2, 2008 Share Posted October 2, 2008 You can buy the HKS GTSS kit that comes with everything you need. If you buy the Garrett Turbos, how much would it cost to buy all the other stuff seperately like gaskets, hoses, etc, etc that comes included with the HKS kit??? Anyone know?? ie: How much cheaper is it to buy Garretts and the other stuff needed vs buying the complete HKS kit? Ive seen the HKS GTSS complete kit for ~3K - 3.4K. Ive seen -7's for ~ 2.5K for two. Link to comment https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/#findComment-4172141 Share on other sites More sharing options...
