hi ive read the rb26 turbo upgrade section and ive settled on 1 of these turbos
i really want a quickish street car with the occasional motorsport/drag event . say 300awkw . more is good if its not at the expensive of lots of lag . im looking for something drivable .
obviously the -7 with .42 comp should be best but a few people have mentioned it comes on boost very severely with the -5 having a much smoother progressive power delivery which might be better for a daily driver
if anyone could shed any light on exactly when and how these turbos would come on boost it would be appreciated.
https://www.sau.com.au/forums/topic/137067-gt2860r-7-or-5-response/
  • Replies 72
I always get mixed up between the 3 trims, -10, -7 and -5.
One of them is like the HKS GTSS, and will be the one you are after, will get you around 300kw at the wheels, very responsive. the next one up is a bit smaller than the 2530's, and will get you around 340kw at the wheels, still very drivable, probbaly a touch more lag if you can call it that. the next one up i don't know much about.
A smaller turbo normally comes on boost more progressively and smoother, doesn't feel as fast because it doesn't give you as much of a kick in the back.
GT2860R Turbo spec's (please choose -5 or -7)
GT2860 Turbine (-5) (Similar to the HKS GT2530) :
-Wheel: 53.85mm w/ 76 trim
-Housing: .64 or 0.86 ar (with wastegate divider)
GT28 Compressor:
-Wheel: 47.2mm inducer, 60mm exducer w/ 62 trim
-Housing: .60 ar
______________________________________________________
GT2860 Turbine (-7 similar to the R34 Nismo N1 Spec or HKS GTSS):
-Wheel: 53.85mm w/ 62 trim
-Housing: .64 (with wastegate divider)
GT28 Compressor:
-Wheel: 44.5mm inducer, 60mm w/ 55 trim
-Housing: .42 ar (not much smaller then 0.60 AR on the -5)
also i belive things like exhaust manifolds and cam gears will help make boost earlier ?
when would these turbos actually make full boost ?
hello,
-5's with Poncams,Dumps and Computer will get you your figures you are after.
Full boost on mine, without poncams come in at 4500RPM.
You wont get those figures with the ss(-9 )or n1(-7) unless you do some engine work.
The gt-rs(-10)_ for Rb26 will have to much lag for day to day driving.
Hope I have been of some help.
Cheers
Tekin :)
will cams make it come on boost later but have more top end ? or will the low end be the same ?
With the Poncams 260Degree with 9.15mm Lift responce is better through the low,mid and high ranges.
Boost comes in earlier around 4300RPM with the set up I have mentioned.
Other cams give you high end power figures only..Some mods to spring,retainers and even higher head gasket are needed with higher lift cams.This is not cheap, check out some pricing and you will see.
These cams are only good for top end power delivery,mid range is slightly higher than factory units
Poncams also work with standard computer,,,so in Melbourne if you get busted :no: with a Powerfc,
there is no problem installing your old computer back.Poncams are a bolt on and off you go unit.
But getting back to the original topic.............if you are just after some useable power gains.
Buy the -7 or -9 Turbo's get some dumps, throw in the Poncams and you can be expecting to get
280AW kw's with a good tune(even a standard computer)at 1.3Bar.
If after all this you want a little more power, then the N1's or ss Turbo's will not take you there.
(Unless you spend a bucket-load on the engine.) :laugh:
So the choice for me was obvious, I bought the -5's.
These will see me to 310AWkw's
Correct me if I'm wrong, but the -5 is the 2530 size and -7 is the GT-SS size :)
Yeah :wub::rofl: your wrong.
This is why I have a Warn,10% under my name.
Tuneagent listed them as you have stated Ronin 09.
How do you get that warning off? :laugh:
When do I get my 12 points back :(
Arkon,
i have the -10's fitted to my R32 GTR & got the HKS actuators as the -10's don't come with actuators.
i have plenty of bolt on mods but no cams or anything as yet. i got these turbo's because i have another engine & can put up with the Lag untill i put stage 2 in.
basically the -10 won't hit more than 0.5bar untill 5000 RPM, but when they come on, boy do they come on, 1.2, 1.3, whatever the're set to in an instant!!
I like em, big plans ahead!!
here's the mods at present with the -10's (laggy as hell)
Tommei S/S Extractors
Twin Garrett GT2860R (707160-10)0.6/0.64A/R (450hp models)
HKS Actuators
HKS Dump Pipes
HKS Front Pipe
Cat removed & 3” full back
Splitfire coils
NGK HITOP Iridium Plugs
APEXI FC & Hand Controller
600x300x125 FMIC (cut the front out to match the IC/8” Ducted air tubes to POD filters)
APEXI POD intake
NISMO FUEL PUMP
Nismo Adjustable Fuel Pressure Regulator
SARD 720cc injectors (not yet installed)
Water/Methanol Injection
Wide band A/F meter
HKS Twin Plate Clutch
PAR Racing Products Gear Set, straight cut 1st, 2nd & 3rd Helical 4th & 5th, Beefed up Synchro shift.
Greaddy Prfec B Spec II Boost controller
Apexi RSM Speed Limiter cut & G Sensor
Arkon,
HKS Actuators
HKS Dump Pipes
HKS Front Pipe
Splitfire coils
APEXI POD intake
NISMO FUEL PUMP
Wide band A/F meter
edited
Edited by bnr#@
  • 1 year later...
Im sorry to pull up an old thread but....
im in the process of buying a set of either -5 or -7s (for some reason they are the same price??? so it warrants some research)
basically im buying the new turbos because Ive just joined the "ZOMG there goes my rear turbo" club.
so im running stk everything but a cat back exhaust.
eventually ill get another ECU, dumps, front pipe and search for about 300kws.
my question is, what turbos will be more responsive with minimum mods? -5 -7? also what will suit my 300kw application better?
cheers
-9's are also now an option. They are the closest match to the GT-SS. The compressor map is very nice indeed. Has the very close efficiency island at the 30+ airflow to the -5's , where the -7's are going to be pumping that sort of air with alot more heat. They appear to be a newer style? With the best of both worlds for those wanting to make the airflow over 250rwkw + with less effort than the -7's.
With these -9s ( i have searched and have seen disco talking about them alot) and the HKS GT SS turbos will they reach 350 rwkw? I'm trying to build an awesome responsive std stroke 26, paying particular attention to getting the exhaust and inlet flow in the head right up (mostly exhaust as they are quite poor standard). My aim is 350 rwkw and i want to be able to make this on pump all day. I have all the parts just not the turbos and oversized valves at the moment.
Cheers
-7's are the most responsive out of them models. Garrett equivalent of the HKS GT-SS turbine, good for up to 350rwkw.
Speaking of which I got a set for sale, in spanking condition :P
the garrett -9 is actually the HKS GT SS equivalent, its the actual same turbo as the gt ss, the garrett and hks cartridge numbers are actually the same.
You can buy the HKS GTSS kit that comes with everything you need.
If you buy the Garrett Turbos, how much would it cost to buy all the other stuff seperately like gaskets, hoses, etc, etc that comes included with the HKS kit??? Anyone know??
ie: How much cheaper is it to buy Garretts and the other stuff needed vs buying the complete HKS kit?
Ive seen the HKS GTSS complete kit for ~3K - 3.4K.
Ive seen -7's for ~ 2.5K for two.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
