My R32 drifter project has started.. :(
Here is my RB25DE that we picked up yesterday.. it ended up being out of a r33 not a r32 like we thought..
Bridgestone Potenza front coil overs and springs.. & JIC rears...
New upper and lower nismo control arms..
Coilovers & upper control arms intalled..
Lower control arms installed..
I will keep this thread up to date with he conversion.
:laugh: I'm SO excited!!!
Edited by RB_turbo_bitch
  • Replies 160
Posted Images
so your going to turbo the NA motor?
Yes that's right!
hmmm 33 na 25 is going to make things a little harder yes?
Yes correct... i was actually wanting to get the non vvt rb25 but this is the one we ended up with...
I didn't even know Bridgestone made coilovers
Are you going to leave the motor as a high comp. NA when you turbo it?
I didn't know they made them either!
We are putting a 2.4mm head gasket to lower the compresion down quite a bit.
hey matey
im doing exactly the same conversion...
right now actually.
i've got my 25DE sump at the engineers getting the 20DET oil drain welded into it.
Other than that, im gonna rock the 10:1 CR and the 260 cc injectors with the stock RB20 ECU, stock turbo and manifold and im gonna use a 1980's apex AFC to richen things up a bit.
by they way, im gonna be running natural boost and aiming for around 160 kw at the wheels
hey matey
right now actually.
That sounds interesting andy! Can i ask why you aren't using a thicker head gasket to lower the compression? I was told that is the first mistake most people make when doing this conversion.
I have a Blitz access computer going on mine and some GTR injectors..
I am using the RB20 manifold and bits of my old engine..
and an RB25 Neo turbo (for now that is) :happy:
andy,
ermm... whats natural boost? :happy:
You mean standard boost, i.e no aftermarket boost control apart from the std actuator?
and yes lowering the compression via the thick headgasket works but it does increase fuel consumption and makes the motor detonate easier.
With regards to the rocker covers thing.. My R32 RB25DE (nonvct) looks identical to my RB20DET. The only way you can tell it apart is by looking at the size of the valves, combustion chamber and ports. So once its bolted on you can't tell the difference between the rb20 and rb25.
hey matey
right now actually.
so are you using the stock rb20, or rb25 turbo? if its the rb20 i think you would be better off with the 25 turbo, as it isn't going to be as close to maxing out... unless you don't plan reving over 5000rpm.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
