Correct me if I am wrong, but changing the diff even if the ratio has changed wont make the speedo read incorrectly as it is measured off the output shaft from the gearbox.......
I might be wrong though :laugh:
Of course it's gunna be wrong if you change the final drive ratio. The speedo will read the same speed at the same rev-gear settings as it used to, but it wont correspond to the actual roadspeed
Shorter final drive ratio (i.e larger number after change, like 4.11 ---> 4.375) = Lower actual roadspeed than indicated on guage
Taller final drive ratio (i.e smaller number after change, like 4.11 ---> 3.57) = Higher actual roadspeed than indicated on guage
The ratio tells you how many times the pinion turns for each revolution of the crownwheel
Hope this helps :laugh:
I stand corrected
Thanks
Thanks Shaun that helps alot, i raise this question because i suspect my diff is not stock. and the actual road speed is slower than what indicated on the gauge. (10km/h slower - was determined by Tom Tom GPS)
how do i know if my diff isnt stock?
cheers
A chassis dyno will be able to tell you what percentage speedo error you may have fairly accurately- get the operator to set the roller speed to 100km/h and see what your speedo reads, then again at 150 or so. You can then work out what % it reads over or under the actual speed.
Somewhere on this site, you should be able to find out various ratios, but some i know are-
R32 GT-R (GTS-t too?) - 4.11:1
GTS4 - 4.375.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
