no need :P SAU NSW are invited to all their events.
The next main track day at bathurst is the first weekend in december, I am getting a copy of the entry form and supp regs when they are ready,
cool keep us posted as i really want to do bathurst
1 min 45 on the game v8 super cars 2 bathurst can you do better i smashed stevo smoky shaun and i would destroy all others who try and stand before me HA HA HA HA HA ! :(
regards andrew
FIRST THE SUPERCARS GAME
NEXT....WORLD DOMINATION
as the name suggests, it's a 1 mile drag with a flying start. It's a top speed run. Fastest top speed over the run wins. I have a feeling it may actually be flying 1/8th mile, or flying 1/4 or even 1/2 mile though. could be wrong, maybe they do run a 1 mile drag.
nope....its a full mile, or maybe more....from conrod right down to the start/finish line from a standing start :P
Details of the weekend are up here: http://www.skylinesaustralia.com/forums/in...howtopic=138446
So lets go! everyone who wanted to have a run there get your forms in!
