Hi ppls,
I've been toying with the idea of an auto for quite some time now and decided to bite the bullet.
I've got a second hand wrecker R32 RB20DET 5speed in the car that has done around 15,000km's. Its recently had new oil dropped in it (castrol synthetic), shifts nice and there's no input shaft bearing noise. So it appears to be a tidy box with no leaks.
It hasn't had a hard time behind the rb30det as its valve floating and is still up around the 176rwkw mark on standard boost.
Not so long ago I replaced both the clutch master and slave cylinder.
So any of you R32 owners willing to basically do a swap of the running gear?
Pedals, console, gearbox, flywheel, tail shaft (if required) etc....
Let me know if your interested... More than welcome to test drive the box before the swap as I would expect the same in return. :O
If not expect to see me flogging off an rb20det gearbox and the other bits in the near future. :)
Auto + MV Auto's stage 1 shift kit + possibly in the future when required 2800rpm stall converter (that retains lock up) here I come. :mad:
https://www.sau.com.au/forums/topic/137690-wanted-r32-gtst-auto-owner-p/
  • Replies 41
autos are ghey :)
nah this sounds like a great op for someone looking to got manual, if i had an auto id definately jump on the chance.
lmao.. You clearly haven't been in a decent auto. :mad:
Manual's are fine for low power and little rb20's but for higher powered rb25's and rb30's with big turbo's they are simply awesome.
Joel, Have you lost your mind.......... Skylines Must be manual!!
Be prepared to spend a fair bit of money to build a tough enough auto to handle the RB30 torque. A mate of mine with VL turbo has spent $3500 on building his Auto, has blown once, still not happy with it he is going manual.
lol... :whistling:
Andrew, The Auto VLT box's are simply crap, I did question MV Auto's about them and they said to steer clear and don't waste your time with them.
The Skyline box's are considerably better and hold 300rwkw all day everyday, they begin to have issues up around 350rwkw. They do however require a stage 1 shift kit to prevent flares etc on shifts when running a PFC. I did ask about rebuilding it and they said... "Consider it once you start nudging 350rwkw and if you are going to be throwing slicks behind it" The R32 auto box's are apparently the same with a different convertor and something else but 'apparently' according to MV's just as tough.
Another Darren (forget his SAU Name many you know) who is good mates with shaun pushes 373rwkw through his R33 Rb25DET box behind an RB30ET with large cams, GT42 turbo and makes good power to 6900rpm. His auto has been toughened up a little but he too said the same thing... Don't touch the VLT auto box's.
The Auto VLT box's have issues with a mere 13psi through the std turbo. They begin slipping and flaring on gear changes etc.
Consider it an experiment, if I like I will stay, if not I will drop a manual back in. From the little spin dangerman4 took me on I was rather impressed. The turbo loves the auto, it never actually felt laggy and this was a .82 GT35R on an RB25 which by all means should feel as laggy as hell.
What was it Darren (dangerman4), 5psi by 3000rpm and 26psi by 4200rpm? :(
ahh well... I've had both auto's and manuals in all my previous cars just to see.. This is no different. :)
Shall be interesting but.. Andrew, I'll take u for a spin once its in.
What Andrew said!!!!!!!^^^^^^^^^^^^^^^^^^^^^^^^
Joel you said just yesterday that you wanted to stick with the manual? what suddenly changed your mind?
I don't care about the lag part, with the torque of the rb30 who cares, i'd rather have a bit of fun with the manual than fall asleep with an auto, its just cheating. I also thought that you couldn't run a power fc with a nissan auto?
lmao.. yes I was in 2 minds but after speaking to Darren (s3_girl) who also went from manual to auto and then driving home and remembering dangerman4's auto I thought bugger it. If I can do it for next to nothing why not; realistically I'm going to be up around 2k to drop an RB25DET manual gearbox in with its required tail shaft mods, cross member etc. The stock box just isn't going to handle the power its going to be pushing out at the end of the year.
The PowerFC's work fine with the 'dumb' R32 and R33 auto's.
The auto's are nothing special with regards to their ecu requirements.
There's a number of people running around with PFC's and Auto's. In Adelaide I know of 2; 4door sleeper & dangerman4 (who's pushing 317rwkw though his stock auto)
As I said earlier... shift kit to prevent any flaring and they are fine.
and auto's boaring.... not when you can give it one big tromp and have it click in to top gear smoking the rears almost on the spot. Or how quick and consistent they can scrabble off the line.
Can't do that in a manual. :ninja:
Getting power to the ground is much easier and controllable. Sure not as 'responsive' leaving corners etc but I've never railed around corners anyway... Which is why I've never thrown lowered hard suspension on the car.
Maybe one of you auto owners should take a little incar vid to show others what all the fus is about. Stock turbo, yea it may be boaring but once the cars making some decent power the auto's become much more interesting. :dry:
hmmm in car video huh..
who did you have in mind Joel? :ninja:
LMAO.. :D
oh........... anyone. :(
Had a VL Calais turbo with 360rwkw with a stage 3 shift kitted auto / 3 grand stall converter and trans brake - just outstanding to drive and ran a 10:39 at the drags..........much faster than an equivalent powered manual!
oh, i have no doubt a rb30 auto would be insane, im just sayin a manual would be better :/
It really depends what you define as better.
If you enjoy railing around corners and punching it out of corners then yes the manual will be better.
If you no longer feel the need to punch it through corners but would rather have something as quick as possible and as tractable as possible to the speed limit then the auto is the only answer.
I've had the car for almost 5years now and done plenty of punching out of corners. Its time for a change; especially as I have the family thing going now also.
As you see its subjective. :)
i have a r32 gts t auto box with tailshaft and shifter thats done 70.000 ks come from a nice clean car that was converted to manual you can have for 150 bucks the lot im in adelaide if thats anygood to ya
cheers dean
Edited by mid life crisis
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
