Guys,
Took my GTR out to Mallala on the weekend and found that after a couple of hard laps the water temp was sky rocketing up to a maximum of 119 degrees!!! Having trouble understanding why it has gone so high with the cooling hardware I am running:
R34 RB26
Apexi big aluminium radiator
Nismo uprated radiator cap
standard viscous fan / shroud
Carbon full length UAS air guide
The car had no pinging at all (max 34 knock value on the d-jetro pwr fc), the oil temp thanks to ARC coolers went no higher than 80 degrees, and there are no leaks etc in the cooling system. I found under full noise the temp was increasing 1 degree every 10 or so seconds - and once I backed off to drive around and cool it down it took ages to get down to under 100 degrees. This temp is verified by 3 seperate sources so I believe I can discount gauge error (pwr fc / dash temp gauge and defi water temp gauge all within +-3 degrees)
I thought for one that the R34 runs a N1 pump on it, and the car behaves normally on the road with normal operating temp being 89 - 90 degrees although I believe this to be a bit high. Do these symptoms sound normal for GTR's on the track with similar mods/ hp to mine, or do I have an issue somewhere else. Looking for guidance as to fixing this from those with experience on the track with GTR's please, although come to think of it any help greatly appreciated!!!!!
Blue32
https://www.sau.com.au/forums/topic/137948-cooling-issues-please-help/
It does sound wierd that you are getting water temps of nearly 120 but oil temps of only 80. Normally they would be much closer since they both come from the same hot engine.... Only thing i can think of is ducting, need more air flowing through the radiator, maybe you have a big front mount in the way? WHere is your oil cooler located? Have you bleed your water system? no air?
something is seriously wrong with your cooling system. on the street yout temp should be between 80-85 max for water temp. 119 is nuts there would be pockets of it boiling for sure by then. start with a flush, and bleed. check thermostat operation. that should be a good start.
Thats a good point, make sure your thermostat is opening, always the simple things.
Thanks guys - I'll start with a thermostat change and go from there. The temp on the street today with ambient temps around 25deg was 89-90 without a/c! Gotta be something wrong with the thermostat I reckon. How do the GTR water temps go on the track normally? Maybe we could post up our experiences with water temps at the track vs ambient air temp on the day, cooling system mods, and power the car is producing? Then we could all easily have a benchmark to check against and beable to tell if the cooling system is doing its job properly??
Use this as a template if you like
Car:
Power:
Cooling system mods:
Water temp on street:
Water Temp on track (incl ambient temp):
CAR: 1990 R32 GTR
POWER: 350awkw
Cooling System: PWR213 radiator - cant remember thickness with twin thermo fans
Water temp street:80
Water temp track :95 highest ever after 15 laps of national QR track (ambient 32-track 48)
Oil temp : 100 and stable during 15 laps national track QR edit -forget to mention Greddy oil cooler
Edited by gtr660hp
no need to bin it straight away, put it in a bucket of hot water with a themometer and slowly add boiling water till you see the thing fully open, then note the temp. check the workshop manual and see if it's on target (should be around 78 degrees or there abouts).
my GTR
270kw atw
stock radiator, stock thermostat
massive Greddy oil cooler ducted in the passenger side duct
water temp on street always between 78 and 82 even when hot outside, or punishing it.
on track never above 90.
oil temp varies a bit but on the street it's mostly around 80-85, sometimes up as high as 90 on the track it's been as high as 105, but water temp still faily stable.
also do you have a massive thick intercooler? if so that will be hurting your radiator performance badly.
and like it was said earlier, bleed the cooling system, there is a valve on the plenum, open it start the car and let it run until water bubbles out of the bleeder, then close it back up again.
Yeh, do the basics. Remove the radiator and give it the pros to give it a flush. Even then if the car is new to you it may not hurt to put a radiator flush through the engine and then top it all up with a good coolant.
Never mix brands or types of coolant...if your not sure whats in there then dump it all and start again.
The bleed the thing properly as Duncan suggested (I think thats all it is)
Does your aftermarket radiator have a shroud on it? Is it as well sealed as a std radiator to the supprot panel etc
Removed the radiator and sorted out my cooling issue on the weekend! It was a partly blocked radiator - containing calcium flakes which kinda look like rust flakes. Reverse flushed the radiator and in the end after I machined up an adapter to put the garden hose and the air compressor on the bottom hose, extracted some 2 or 3 table spoons of calcium build up. On initial removal, ran the garden hose through the radiator and the flow was pretty slow compared to after the flush out. Also completely flushed the engine using my hose and compressed air tool and found more within the engine. Also the thermostat in the car was a 65 degree one instead of the 76.5 factory nissan one. So now the car has a flushed system, with some tectalloy flush solution and water (until the weekend when I will reverse flush it again), a new genuine nissan thermostat and a new trust 1.3 bar radiator cap! Temps on the street today with a 28 degree ambient temp was 80-81 with the aircon on!!!!!!! Previously last week under same ambient conditions I was seeing 95-97 degrees.......... Calcium flakes due to previous owner mixing coolants - a lesson to be learnt for everyone on this one!
  • 1 month later...
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
