240Z pilot October 9th, 2006 10:05 PM Link
I guarantee this car will be significantly HEAVIER than the “7 litre us tank” referred to! Z06 Corvette weighs in at 3150 lb., this will be at least 3400. I’d bet money it will also be SLOWER around any race track.
To tell the truth, I’d rather see a new Silvia (which we haven’t had in the U.S. since ‘98)!
This thing is a bit “much of muchness” imho.
Less is more!
idiots...
Theres another thread posted recently with pics of the car without the car bra and hiding stuff but I think it is still labeled as the prototype.
http://www.skylinesaustralia.com/forums/in...007+skyline+gtr
Drew.
:P idiots...
Its not that much of a stretch of the imagination.
The current Z06 runs a 7:43 around the Nurburgring Nordschleife. That's significantly faster than a 996 Turbo, a 415hp / 3800lb AWD car with a purpose-built chassis and a lot of money thrown into performance R&D.
That said, I don't think Nissan will be happy with the GT-R until it holds the lap record for a "reasonable" production car (I don't count the Radical SR8 as "reasonable", even though technically it is a production car). And the 996 is a generation old, now, but I don't have the times for the 997 Turbo. It should have cracked the 40's by now, since the old 996 Turbo / light tune R34 ran a 7:51 or so.
I think the next GT-R will be quicker than the Z06 on the track, but given the sheer pace of the Z06 its not going to be your typical "AWD turbo terror vs Yank Tank" battle, especially in the hands of drivers who know how to make a car go around a track fast.
The real thing looks the goods thats for sure.
The one problem I can see with this is, nissan isnt seen as a premium brand, therefore the people with the money are going to be hard pressed to justify spending the dollars to buy it, as it doesnt have the 'badge'. Because really a clubman will go around a track as quick as a porka at a fraction of the cost, and a VK with a worked V8 in it will go in a straight line faster at a fraction of the cost. But the people with the money wouldnt do that as they dont have the badge. Ones a mechano set the other is well a commodoore.
But yeah, good luck to it. Its definately got all the good gear.
people still thinking it's a Skyline after it's been explained it's NOT a million times, others thinking there is going to be a V8 for the US market only? no... they're idiots :)
Other sites are linking to 2005-dated information saying it'll be badged Infiniti over there as well.
Its almost the end of 2006, for Christ's sake.
I love it how people are still quoting the info I posted from back in 2004:
http://www.leftlanenews.com/2006/10/09/spi...08-nissan-gt-r/
Rumours have indicated the car will feature a 3.2 liter twin turbo V6 engine with 480hp.
Which lets face it, isnt most americans who think in 1/4mile and not much else, guess theres the handful of people outside of NASCAR that actually know how too turn right as well as left.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
