guys, ive been searching for results but nothing!
how about creating one of those results register threads, just like in the turbo section.
if everyone can list their results, wat engine, modifications and maybe dyno graph.
i think itd be good to look for ideas to do to our na engines. i plan on puting a rb25de in my r31, and i want to know power people are getting :/
i might as well start, but its nothign special :)
rb30e, extractors, rear muff gone, auto. 85rwkw. almost too much power :sick:
*Good Idea, sorry to edit your thread*
Eveyone Please put results only No chit chats- Please edit your comments like one below
eg.
Model - R34 R33 R32 R31 R30...etc
Engine - RB20DE RB25DE RB26DE...etc
Modifications - Intake system Extractors...etc
Dyno tune results...etc @ what RPM...etc
MISC -other infomaitons
Thank you all
Glue :kiss:
Edited by Pva_Glue
https://www.sau.com.au/forums/topic/138169-na-power-results-all-na-engines/
  • 4 weeks later...
r31 skyline
rb30e
3-2-1 exstractors 2.25" exhaust with a very restrictive muffler.
chip. adv timeing, k&n pod plus CAI
unknown power figure but around 110rwkw.
last runs was 90 rwkw with only exhaust shity pod
done a 16.3 @83mph at calder drag strip.
  • 3 weeks later...
Model: R33 series 1 GTS25 sedan
Engine: RB25DE
Mods: converted to manual, K&N pod filter, 3" custom intake pipe, CIA, extractors 6,2,1 heat wrapped, 2 1/8" exhaust cat removed, GTS link ecu
Power: 117rwkw
  • Like 1
Engine: RB25DE
2 door Coupe
GT-4
92.5kw (on all 4 wheels) @ 5814rpm
831.6Nm @ 4325rpm
mods: pipercross panel filter, 2.5" catback exhaust
this is going to be my baseline for modding my car, at least I know how much it pulls now..
any suggestion which other mod I should do next? pm me.. don't reply here =)
Edited by HolyEvil
  • 1 month later...
Model: 1987 R31 Skyline Ti
Engine: RB30DE with VVT
Modifications: Extractors, exhaust, twin tb, safc untuned, billet f/wheel, reground surecams, 10.5 compression, 18 degrees timing, 98ron ultimate
Power: 150.9RWKW @ 172kmph an 507nm (374FtLb) torque at 144kmph
with more left in it, she's an economical daily but rich and restricted above 5000rpm so once thats tuned/fixed i'll be a happy camper
  • Like 1
very impressive skit. what 1/4 mile times are you running? i expect low to mid 14s?
model: r33 gts25
engine: rb25de
dyno dynamics
modifications: custom air intake, pod filter
power: 108.4rwkw
dyno logistics
modifications: back to standard panel filter, coby extractors, 2.5" cat and 2.5" cat back exhaust.
power: 101rwkw
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
