Just for a laugh.
1985 honda civic
890kg
1.6l DOHC ZC (not vtech yo) jap spec engine implant. 130HP at the crank from factory.
Mods: Extractors
rev cut 7500
15.5 down at WSID
100HP atw (75kw) lol at R31 club dyno day
Don't have it anymore.
My friends setup
R33 GTS
Rb25DE
-6-3-1 Custom Extractors > 2.5" Exhaust > Oval Muffler at rear
-Pod Filter in fibreglass box with a S/S intake pipe with factory AFM
-Apexi PowerFC
-GTR Injectors ( i think he said , not sure about that one)
-111.5rwkw / 149.41rwhp
VL Calais
RB30E
-6-3-1 Extractors > 2.5" Exhaust > single Oval Muffler dumped at Differential
-High Flow panel filter into custom Twin Throttlebody setup
-Tuned and Chipped factory ECU
-93rwkw
  • 1 month later...
  • 3 months later...
  • 1 month later...
ok, well i will list my 2 natro cars that i have had on the dyno (neither skylines though). will scan dyno sheets when i find them.
2000 n15 SSS pulsar
genie extractors
2" press bend system (which i want to get redone because it is just one we bodged up 1 arvo) with 12" centre resonator and lukey muffler (not a cannon)
k&n panel filter
fuel - dunno. probably 91 octane. can't remember
112hp atw (approx 84kw)
2000 mitsubishi magna (3.5L manual)
first run: 100% stock, rear muffler was a cannon, but rest of the piping was stock
159hp atw (approx 118kw)
second run: pacemaker extractors, 2.5" redback centre system (cat to rear axle), 2.5' lukey rear system k&n panel filter
170hp atw (approx 127kw)
1999 magna (same as previous one, manual 3.5L)
never dyno'd, but felt more powerful as the previous one had been thrashed a fair bit.
redback 2.5" exhaust
14.8 at willowbank with 2.18 60ft time
just found all my dyno sheets, etc
pulsar
first magna (and people say that you can't get a smooth dyno graph from a stock ecu, LOL)
second magna drag slip
Once I get my extractors I hope to get them installed and tuned and get some power figures up
The setup will be as follows
1992 E-HR32 GTS
RB20DE (Automatic)
COBY 6 -2-1 (2.5 outlet) to standard cat then 2.5" exhaust back to a canon muffler (loud)
Large K&N pod filter on stock intake piping (will modify later)
R33 series 2 - 4SPD Auto box (re4r01a) Which has a Stage 2 modified valve body
R33 series 2 torque converter
Advanced timing
Always have run on 98 octane premium Shell or caltex fuel
Suspension and braking below:-
Complete nolathane bush kit
Japanese Aluminium adjustable front Strut brace
Pedders Larger rear sway bar
Pedders sportsrider lowered suspention all round
R33 N/A Complete rear brake setup (4 stud)
R33 GTS-T slotted Front Rotors (re drilled to 4x114.3 pattern)
R33 GTS-T - 4 piston Front calipers (gold painted)
17" SSA wheels with 215/45R17 rubber
Looking at between the 100-120 Rwkw mark hopefully
2005 VZ SS ute
5.7l GenIII
4spd auto
cold air intake
Pacemaker extractors
HSV hiflow cats
2 1/2 inch stainless twin system with rwc muffler
LS1 Edit
239.9rwkw at aussie mufflers dyno
its running rich in the top end for towing duties, If i where to lean it out and get a retune, it would make about 260kw.
  • 1 month later...
  • 1 month later...
Just an update, had new exhaust put on the car, went from 137rwkw to 152rwkw, so i'm finally making 200hp at the treads.
Went back for a Retune with the new exhaust, I am now making 154.6rwkw (207Hp) as far as I know it's the 2nd most powerful N/a RB in Australia.
nice!! goes to show that if you invest $$ into an N/A RB you can still make some good N/A power! Do you have a dyno graph? I'm interested to see visually what the power delivery is like. What's the torque like down low being that it's an RB30/26, I'd expect it to have some nice bottom end.
nice!! goes to show that if you invest $ into an N/A RB you can still make some good N/A power! Do you have a dyno graph? I'm interested to see visually what the power delivery is like. What's the torque like down low being that it's an RB30/26, I'd expect it to have some nice bottom end.
This one doesn't have the torque curve on it but it sits almost flat from 2000 to about 6000rpm at around 350Nm.
  • 4 weeks later...
Not for long :down:
Nice graph though, would be really nice to drive, mines the same but a bit of a gap down low and it keeps climbing up top (more duration cams).
If you gave it some mild cams i reckon you could easy net another 15-20kW from it (but atm it looks like it would have beautiful drivability)
  • 3 weeks later...
  • 3 weeks later...
It's not mine, but my cousins manual MR30 with RB30/25DE made 144.6rwkw with a Haltech, injectors, 6-3-1 extractors, 2.5" exhaust and a K&N pod
Never owned a Skyline, the only car I ever put on the dyno was my Scorpion with extractors, a Weber, 2.25" exhaust and 5 speed, it made 67rwkw :huh:
Edited by jwebb2876
Rb 25 NA standard internals; nvct; 256 -degree Tommie cams; custom plennum with Falcon T/B; custom 6 into 3 into 1 extractors(no cat); Autronic set at 22 degrees-164 rwlklwts at 7600 rpm on Jakes Dyno( ACT ) in clubman sportscar road registered and 720 kgms
Engine:VQ35DE
Car: V35 Skyline Coupe
Mods: Z-tube and pop charger, Plenum spacer.
Power: 177rwkw.
Putting the Exhaust Headers on monday and a grounding kit. Will do a new Dyno run sometime next week. :bunny: Hopping for 185rwkw
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
