1998 EL Falcon
NA6 4.0L
lots of headwork, big cam, 3" exhaust, Wolf V500, ICE ignition, CAI.
198.9rwkw
That's a good figure man, any vids?
I'll have to post up some figures when the LS eventually gets tuned
  • 7 months later...
2007 V36 370GT VQ37HR 3.7L V6 5SPD AUTO
Modifications:
Cat-back exhaust pipes
Hi-flow panel filters
Apparently car runs rich from factory, bit more power to squeeze out of it if I can lean of the a/f ratio a bit
Stock Power run done close to when I first got the car for reference:
Hey mate, just wondering if you had the 180km/h limit when you did the dyno run as you have not mentioned an a/m ecu, if yes what gear was the run done??? cheers
By the speed, 3rd automatic.
4th gear will be in the limiter.
  • 3 weeks later...
Naturally aspirated RB26/30 R31 Skyline build-
Nitto high volume rb oil pump
Nitto h-beam connecting rods
Nitto crank collar
Nitto high compression custom pistons
ACL Race bearings - mains / connecting rods
ACL Race ProSeal engine gasket kit
Brian crower 1mm oversize valves
Ross metal jacket balancer with cam / crank trigger kit
N1 water pump
Nismo low temp thermostat
Oil restrictors
Camtech RB26 camshafts
Camtech valve springs and titanium retainer kit
Custom made ITB setup
XSpurt injectors
Heavily ported cylinder head
Link G4 Storm ECU
Genuine Nissan front / rear seals, idler and tensioner
Custom Gates belt
IGN-1A race coils
Dyno sheet - Mild Tune (will push it a bit later when its proven to be all well)
Engine torque is that divided by the diff ratio. 3.7 in this case
Annnd its on a hub Dyno hence the power curve "interuptions", if it was on a roller it would be smooth as silk.
  • 1 month later...
Nitto crank collar
N1 water pump
Oil restrictors
XSpurt injectors
Link G4 Storm ECU
Custom Gates belt
IGN-1A race coils
Post up a sound clip or vid, I wanna hear those ITBs :yes:
  • 2 months later...
So yer only took me a year to get around to it. Cam only through a stalled auto ;)
  • 7 months later...
  • 4 weeks later...
Hello, I have a 1998 R34 coupe and im having some weird problems.
The other week i got in to drive it and when i unlocked it problems started,
1. The tacho and speedo dont work,
2. The bell chime for door didnt chime,
3. The interior light stays on,
4. The passenger door wont lock with the button on the remote or drivers side panel.
It still starts and drives fine,
I disconnected the battery and reset the ECU which worked, but then it happened again and again now that trick only works sometimes.
Any ideas thanks
  • 4 months later...
  • 3 months later...
  • 1 month later...
R32 GTS25
RB25DE (small port non VCT R32 RB25)
CAI
Fujitsubo extractors. 2.25 straight through exhaust.
Mild port - exhaust side only.
Poncams.
Tomei cam gears (0 deg on both was actually the sweet spot surprisingly)
Nistune.
98 octane.
158.7hp atw.
Tuned by Matt Spry.
Link to dyno sheet below.
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-xtp1/t31.0-8/11062004_1013167325369234_3421555629321155321_o.jpg?efg=eyJpIjoidCJ9
  • 7 months later...
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
