Hey peoples!
Our timing belt went on the weekend! We have the new belt, were not sure if it has done any further damage? hopefully not ! Does anyone have any idea how to put it back on and in the right spots after its snapped? We have asked a few machanics in town and no one wants anything to do with our car??
Any ideas would be greatly appreciated! its only just got back on the road after the yellow sticker and now this??!!! ahhh
anyway, anything would help.... its a R33 95 GTST
cheers !
https://www.sau.com.au/forums/topic/138247-timing-belt-replacement/
go to a workshop. hyperdrive should be happy to help
if u f**ked it up bye bye engine
they are in geraldton :P
theres a guy at tyrepower in geraldton that owns a white 33, maybe ask him where he gets his car serviced?
Don't screw with it because it is a very important part of the engine! I got mine done at a workshop which will remain un-named, one different to where my performance mods are done, and for that reason I believe they didn't take the care they should have with it. Timing was way out when I got it back, and it made it hell.
Take it to somewhere that has dealt with your car/previous cars before & you can trust. If that doesn't apply, somewhere convenient for you.
DIY I say - I did mine, with a bit of common sense and a willingness to learn its pretty simple :P
Absolutely!!
I have done numerous RB timing belts and a few others. The Gates belts have lines on the. If you point the dowels on the cams up and set the bottom end to TDC then line up the belt marks with the punch marks.
Of course its VERY important not to turn the bottom end independent of the cams, otherwise the valves will hit the piston tops and bend, if that hasnt already happened. The way around this, remove the cams so the valves arent depressed, easy.
Brent.
Brent.
I lined up my cams to the marks on the timing cover, THEN turned the bottom end over 39849384 times to make it all line up with TDC, worked fine for me. I can only assume by this logic that keeping the cams on thier marks, keeps them totally clear of the pistons??
P.S. Yes, my engine is fine :laugh:
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
