My car has a protective layer of grime.
hahah yes that's what it was going to be about... how the heat dried the dirt, which turned into fine dirt. and the wind took it like so. but then i decided it was a boring subject. except i pressed post instead of otherwise.
https://www.sau.com.au/forums/topic/138381-weather/#findComment-2577275
nah only had car window down while it was idling away.
however, here in my room, all my stuff has a new dirty texture to it having had the window down, even with a flyscreen :teehee:
the cat just walked inside and he's a lighter shade of gray
https://www.sau.com.au/forums/topic/138381-weather/#findComment-2577324
Miserable one day...shithouse the next
will soon be replaced permanently with
Beautiful one day - Perfect the next
sif the worlds most liveable city
Melbourne is a hole.
come on man melb isnt that bad i think it is the most livable city in the world :teehee:
Edited by assyrian4evaa
https://www.sau.com.au/forums/topic/138381-weather/#findComment-2577395
HAHAHA
Geoff you forgot to mention the next part of the QLD weather thats never spoken about where it is hot as all shit and pisses down with rain for a good week :teehee:
https://www.sau.com.au/forums/topic/138381-weather/#findComment-2577622
how hot was it today!! then picture me in a mechanic workshop doing a diff in a ba xr6 ute on the freaking floor with dirt and oil all over me!! it reached over 40deg in the workshop.
are u purposely being erotic?
:P
https://www.sau.com.au/forums/topic/138381-weather/#findComment-2578127
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
