Hiya all,
I've just taken these mags off my car and i was told they were genuine nismo LMGT4's (17x9) but regardless of this the wheels didn't fit my GTR (spacers, apparently they're a 30 offset, suited for gsts and silvias), i've had them replaced and now im just trying to identify them. Does anyone have LMGT4s, that can tell me what to look for? cant see any nismo badging, they've got the nismo decal ofcourse, but nothing to suggest the brand by any casting information on the mags.
thanks in advance.
https://www.sau.com.au/forums/topic/138389-nismo-lmgt4/
Hiya all,
thanks in advance.
Mate I have LMGT4's on my GTT. (F 17 x8.5 x 35, R 17 x 9.5 x 38) They do not have any Nismo stamp on them other than the face decal. They should have a Rays sticker on the inside telling you size and offset. It is the spoke pattern that makes them Nismo LMGT4's nothing else. They should be able to be lifted with the little finger (wheel only) as they are forged monobloc construction hence the lightness. Rays make them for Nismo.
From my Nismo catalogue they should weigh about 7.7 kg bare so 11 with rubber is about right. Also details on size and offset can be had from the Nismo site. Scroll down until you get to section 4. It is in Japanese but sizes are in English. Fairly easy to interpret.
http://www.nismo.co.jp/products/productgui.../partslist.html
But to give you some idea, the R34 GTR requires an offset of 12 if the wheel is a 17 x 9.5. The wheels you have would suit an R33 GTST and maybe some others.
Cheers and hope that helps
Muz
https://www.sau.com.au/forums/topic/138389-nismo-lmgt4/#findComment-2577512
Here ya go mate, just match them up with these
awsome, thanks mate,
unfortunately they're not genuine they havent got the "made in japan" and the decal seems a bit smaller on these, and they were also missing the rays brand, which got me suspicious in the first place. The mags i just got put on are drifteks and they seem to have the same badging, seems these ones are just drifteks + nismo sticker. Im planning on selling them, just wanted to confirm authenticity.
cheers guys!
https://www.sau.com.au/forums/topic/138389-nismo-lmgt4/#findComment-2577539
hmm bout 11ish kg with tyres
Muz
hey guys, they will be nowhere near 11 with tyres. tyres weigh a lot more than 4-5 kgs more like double that, i weighed a lm-gt4 17 by 7.5 with tyre and it was 16.5kg. your being 9inch wide should be a couple of kg more than that.
attached is a pic of bronze gt4
https://www.sau.com.au/forums/topic/138389-nismo-lmgt4/#findComment-2577897
Gotta admit I was only guessing on the rubber content. Apologies all round if I have misled anyone.
cheers
Muz
https://www.sau.com.au/forums/topic/138389-nismo-lmgt4/#findComment-2578384
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
