Hi Stocky , yeah probably nothing brilliant unless they've had a fiddle with the wheel trims . Otherwise its just another compressor option for the big shaft GT40 style centre section . I get the feeling that small capacity drag engines like some Hondas may like the 4094 kind of thing . Perhaps its a round about way of saying that the GT42R's are not what some would like them to be . HKS's version of that one (T51R) used a fair bit smaller trim turbine (76 vs 84) so no doubt this was done to get same day turbine response !
There is a GT4594R out there which would have low backpressure for its compressor size .
So far the BB turbos available on that shaft (frame) size are .
1) P/60-1 76mm Compressor
2) TO4Z 84mm compressor
3) GT37R 82 and 88 mm compressors
4) GT4088R 88mm compressor
5) GT4094R 94mm compressor
6) GT42R 94 and 102mm compressors
7) GT4594R 94mm compressor
ETC
Cheers A .
Edited by discopotato03
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
