Does anyone know, or tried the steering rack/mount bushes. I also have seen S13s with alloy bush in the steering rack itself.
Anyone know where to source this gear for an R32? Ive had a look around and its all S13/14/15
Also, Nissan want a fortune for the front and rear tie rod ends. The aftermarket ones are a tad cheaper, but still a lot of money. Have ppl come up with a better solution?
https://www.sau.com.au/forums/topic/138458-r32-steering/
s13 steering shaft spacer is same as r32
one of the guys on here does em for $30
NV N01
just get tie rod ends from a wrecker, theyll do.
EDIT: oh crap, i thought you said steering shaft
Edited by salad
https://www.sau.com.au/forums/topic/138458-r32-steering/#findComment-2578516
Ive got steering rack bushes in mine Roy :(
Old ones were shagged (fell apart as i ripped em out)
Fulcrum suspension do it - Part # SPF2492K (Steering rack Mount Bush Kit) Polyurethane ones
Tie rod ends i got from Pedders - $32 each for the fronts (12mm or 14mm thread size). They have rear as well.
If u want, i can grab you some tie rod ends and send em to you if u cant find em local.
Edited by Bl4cK32
https://www.sau.com.au/forums/topic/138458-r32-steering/#findComment-2578560
  • 6 months later...
I got mine from drift motorsport who is a forum trader.
Fitting took me about 2 hours, mainly because i couldn't get the car up high enough to have any decent working room and the bracket was a tight fit over the new drivers side bush so i couldn't get the thread to catch initially (funnily enough same issue i had when fitting the poly sway bar bushes).
My old ones also fell to pieces as i removed them.
https://www.sau.com.au/forums/topic/138458-r32-steering/#findComment-3078099
  • 1 month later...
  • 1 month later...
I replaced my sloppy wobbly steer rod bush that I bought from NV N01. I painted it black. Excellent fit.
A little tip for when you do it; pull the arm towards you so that you can get a socket on to it, then crack away, spin steering wheel, crack away again. Loosen the lower spline, slide the lower half of the steer rod down and remove the old rubber joiner, fit the new solid and bolt it all up.
Now with slight steering movements I can see the whole rack move side to side so my rack bushes too are buggered. :thumbsup:
No wonder it felt like an old HT Holden. :domokun:
I'll let you all know if there's a noticable annoying increase in nvh due to the solid bush.
https://www.sau.com.au/forums/topic/138458-r32-steering/#findComment-3220855
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
