  • Replies 59
we just had a coincidental meet in burwood at the carwash near VICroads today... we just all happened to be washing our cars at the same time. :pirate: I'm stayin in dandy these days.
we're having a breakfast of champions meet up north tomorrow at 9/10am in mill park.
Im in the s/e suburbs, anything around here ill go to, i dont even mind travelling a bit. Ive only had my 33 about a month and i cant wait to see other ppl's to get some ideas on what to do next. My mate has a supra and he seems to be always having meets etc. so it shouldnt be that hard...i guess we just need more ppl to say that they r in aswell
id much prefer a nite cruise actually :wave:......but days fine also
well post a meet point
post a destination
and go cruise!
every post in here is "i want this, i want that, someone organise a meet"
3 pages, only one meet organised (by the vic-club prez)... how many of you even attended it?
everyones still a lil busy atm....i think thats why no official date or place has been put down.
today is my last exam so ill be all over this sooner then later
nope not everyone...
And ffs.. how hard can it be to go for a 1-2hour cruise... its not like its the event of the friggen year..
What about tomorrow night?
Time: 9.30pm, leave 10pm.
Meet: Somewhere on the East side (anyone think of a place?)
Route: Whatever is decided when everyone turns up.
sounds good mate....ive had a lil brainstorm by myself and thought of a pretty neat place....
just made a new thred....lets try keep it fresh with only the ppl who are interested
ive posted times and places
http://www.skylinesaustralia.com/forums/in...howtopic=142669
Edited by anDru
Me and about 5 (MINIMUM, aka, they are the ones I personally call) other cars regularly meet EVERY friday night. East, West, North, South, Gippsland, Healsville, Portsea we do it all. We normally meet in the East somewhere though, around chadstone/glenny/fountain gate (Basically, off the freeway)
Fridays are my "driving" nights, I NEVER do anything other than cruise.
If you want to do something on any Friday night, PM me for my mobile number/MSN contact and ill make sure you keep you posted on whats going on. Always better to have more contacts to call :D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
