Hi guys, i have just had my car tuned again with the pwoer fc in it, it now makes 246rwkw on 14psi, however it now has a lot of lag, and feels like it's getting slower and slower and the engine light comes on at 7krpm. Can anyone recomend a really good tuner in melbourne? I have taken it abck ot the guy and he doesn't know what to do. Any help would be greatly appreciated. THanks Mark
What mods. Hack advise sounds like its pinging up top of the rev range. Could be simply too much ignition or the fuel pump cant keep up and is leaning out despite how much fuel correction they are tryign to throw at it.
Ring around, there are a few good tuners in Melb, just dont be scared off by advice you may not want to hear :)
Which tuner was it that cant fix it if u dont mind me asking
Thanks guys, relaly appreciate it. I will try and get onto racepace. Have been to 2 on that list and they both stuffed me round and tried ripping me off. I won't name this one as i am not here to tarnish somones name, i just want my car to be fixed. Cheers Mark
I'm not sure what your version of ripping someone off, but just to give you a heads up, a full PFC tune will cost you around 500-800 ... a touchup to your tune may only cost a couple of hundred, depends how much dyno time and tuning time is needed :dry:
What are RE customs and Ice Performance like (And all the other ones on that list)?
Both have reputations.... just would like to hear some personal experience?
Or is it just Racepace hands down as far as skylines go? Tried a search (thats how I found this thread) but cant find anything relevent.
A simple search of the Vic section will tell you mate.
Remember, no business slander or negativity, but most places have a pretty good rep with most people.
So yeah, have a search of the Vic section and you'll get a lot of threads about it all :(
When i went to racepace, all cars there were gtr's including two r34 gtrs :O and a 9second r32 gtr
So they must know what they doing and seem geared towards the performance :(
recustoms is a friendly environment where i have my car serviced as its only a nimble r32 gtst :laugh:
They also install sound systems and seen plenty of mercs getting audio systems
Hope this little info helps
Racepace by far are the most professional and honest workshop I have ever dealt with, I have been to a few, and have been burnt badly, but I have never had an issue with racepace, always top qulaity work, and my PFC tune is brilliant, the car runs better and returns better economy than the stock ECU ever did.
Ive heard very good things about RE customs too. And their pricing seems very fair to me.
Just Emailed them and was told $180 for safc install/tune and calibrate my evc...
by the way 31jet. saw your car in the magazines this month. Love what you've done with it!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
