$1200 - YOU BASTARD !! :D :D that is the cheapest job i have seen, even for "mates" rates. And that job looks very pro as well -you just gotta get a bodykit and some wheels now for it and you'll have a very nice line
Can he do any good deals for SAU members? There is a few things I'd need done on mine...
No, wouldn't be expecting so. But even a reasonable discount to any panel shop is going to be a good deal, as long as its a good job.
I will need my front bumper resprayed soon.... although pearl full body would be nice... :D Anyway, let him know, and if he's ok with doing anything else, i'll PM you what i need doing at the moment and he can give me a bit of a price.
predator: no worries, let me know.
meggala: yeah you could call it a practice job, but hes in his last semester and has been working in the field for a few years.
The pics dont really do the job much justice.. it looks much better in real life :D
coco: I'll find out
hippy: I think it can be put on any colour with the clear coat, how good it'll look is another story. I saw a white gemini with the same blue pearl and it looked kinda... well.. feminine.
The pearl is a sky blue so when mixed with black becomes midnight blue. Its pretty mad, some angles its jet black, when the sun hits it, its mnidnight blue :)
Does this means you don't have to strip the base paint before applying the new coat? Just put the pearl coat on top?
My bonnet has a few fades already as well as a deep scratch on the boot n few other blemishes... trying to justify a full respray of pearly wine red... I guess not even the best french wine could beat that luscious colour :)
Originally posted by coco69
by the way, riggaP, that is some madaSs parking bays you have at yur place... where is it?
photos were taken at a mates place in bulleen... just behind the eastern freeway... he has a white r33. Hes not on the forums...yet
rigga... jus parked nex to ya car today, and I opened tha door a bit too far and put a lil scratch on ya paintjob man... jus kiddn...
i saw ya paintjob but... it looks supa l337...w as lookin at it from all angles, and dis chick walked past n looked at me funny...
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
