$1200 - YOU BASTARD !! :D :D that is the cheapest job i have seen, even for "mates" rates. And that job looks very pro as well -you just gotta get a bodykit and some wheels now for it and you'll have a very nice line
Can he do any good deals for SAU members? There is a few things I'd need done on mine...
No, wouldn't be expecting so. But even a reasonable discount to any panel shop is going to be a good deal, as long as its a good job.
I will need my front bumper resprayed soon.... although pearl full body would be nice... :D Anyway, let him know, and if he's ok with doing anything else, i'll PM you what i need doing at the moment and he can give me a bit of a price.
predator: no worries, let me know.
meggala: yeah you could call it a practice job, but hes in his last semester and has been working in the field for a few years.
The pics dont really do the job much justice.. it looks much better in real life :D
coco: I'll find out
hippy: I think it can be put on any colour with the clear coat, how good it'll look is another story. I saw a white gemini with the same blue pearl and it looked kinda... well.. feminine.
The pearl is a sky blue so when mixed with black becomes midnight blue. Its pretty mad, some angles its jet black, when the sun hits it, its mnidnight blue :)
Does this means you don't have to strip the base paint before applying the new coat? Just put the pearl coat on top?
My bonnet has a few fades already as well as a deep scratch on the boot n few other blemishes... trying to justify a full respray of pearly wine red... I guess not even the best french wine could beat that luscious colour :)
Originally posted by coco69
by the way, riggaP, that is some madaSs parking bays you have at yur place... where is it?
photos were taken at a mates place in bulleen... just behind the eastern freeway... he has a white r33. Hes not on the forums...yet
rigga... jus parked nex to ya car today, and I opened tha door a bit too far and put a lil scratch on ya paintjob man... jus kiddn...
i saw ya paintjob but... it looks supa l337...w as lookin at it from all angles, and dis chick walked past n looked at me funny...
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
