I notice it takes a little while for my O2 sensor to work normally (I think). Here are the steps I take to make me believe my O2 sensor is on its way out.
1. warm up the car.
2. stop the car
3. wait 5 mins
4. start up the car and hook up conzult
For the first 2 mins my idle is slighly lumpy an my timming is jumming from 0 to 20 BTDC. In this time I notice in conzult that the voltage on the O2 sensor starts from 0V then jumps to .3V and slowly moves it way up to .8 volts. Is this normal does the O2 sensor have to be at a specific temp for it to work properly or is it starting to die?
After 2 mins my car idle fine. BTDC sits around 15.
Any help appreciated.
Edited by rmahnovetsky
https://www.sau.com.au/forums/topic/138767-is-my-o2-sensor-dying/
Hey. Just some info on how they work. Might help you detrmine if it's the problem or not.
The voltage should jump from about .3 to .7v and back on idle, every half a second.
It needs to be hot to work and there is a heater in it to warm it up on start. Takes approx 30 sec to warm up.
Does it still take 30 secs for the O2 to warm up even though the dump pipe is still boiling hot. So if my car is at operating temp then I switch it off, then back on after 5 mins shouldn't the O2 sensor still be hot enough to work straight away?
anyone know, or have any idea?
Just hook it up to consult. graph the o2 sensor voltage.
i wouldn't worry too much about the first few minutes when it's warming up. E.g. what you're looking at - like how long it takes to warm up etc, not that important.
What you want to know, is whether it's reading properly once warmed up.
No need for cro. consult can graph it. you essentially need to watch it while cruising
and you'll notice it oscillating.
Then accelerate, it'll go ultra rich.
then back off, it'll drop straight off.
cheers for your input. The sensor is reading fine once the car is running. I dont have a laptop atm so I cant cruise with it logging the data :O. But what I'm concerned with is once when I stop the car from normal operating temp and start it up again after 5 mins, the sensor does not read properly for a minute and the temp guage is just where it was left. I would think the O2 sensor is warmed up sufficently since touching the dump pipe would burn you hand off. Maybe I have intermitent faults with it, maybe it is wearing out and it needs to be very hot for it to work. Im just plucking at straws bc I dont know the internal working of it.
Most o2 sensor cars I have been in once warmed up idles very nicely. My car idle like crap for 1 minute till the sensor starts to work. It seems funny to me as it is only my car doing this. I hope Im right as it would be nice not to waste $70. :(
just installed a ford el bosch sensor.. No difference.. Just for others info the sensor cost $72 at thompson spare parts in caplaba. Repco wanted $106.
I did notice my old sensor was rattled when I shook it. I read somewhere in the forums if a sensor is rattly it is not good.
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
