  • Replies 47
Originally posted by skyzerr33
rogue 5 (6 pack for who works that one out)
Well, lets see.
Maybe a refrence to rogue squadron and luke being "red 5" in a new hope or...
Maybe you liked "The phantom affair" (The 5th book in the rogue squadron series) or...
Maybe there is a fan of the pilot rogue five.
That would be...
Rogue Five = Wes Janson
In the post Yavin Endor etc timeframe..
But in Battle of Borleias
Rogue Five = Riv Shiel
Be he ended up as rogue 7 after Battle for Coruscant then
Rogue Five = Gavin Darklighter.
Riv Shiel comes back as this lucky number for the Bacta war.. but he was not that lucky as he dies :D
So.. step up Rogue Five = Tal'dira
Until they hunt for Warlord Zsinj then Tal'dira dies :(
I'll stop now..but there is more history on this number :)
Proving Troy is not the only Star wars Nerd......
