Can any one help me i have been told that the vg30 turbo off the single turbo 300zx will fit on to the RB25 det neo and that its a good upgrade for a bit more power. Has any one done this or no any one that has and are thay happy with it.
Thanks Ryan
https://www.sau.com.au/forums/topic/139387-vg30-turbo/
I'd say that getting a Sliding Performance high-flow or a Sydneykid group buy GCG high-flow would be a better choice.
But as far as I know , they are slightly larger than the RB25 ones and bolt up with minimal, if any modifications.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-2597608
Thanks Ryan
One answer... No. :mad:
If you run the turbo off a 300zx you will have to change dump pipes etc.
If you were to run a turbo off the later model VG30DET's from the Leopars/Cima's etc then you don't have to change anything; but the turbo's are not matched with 'performance' in mind. The run nothing more than an RB20DET turbo's guts with larger turbine and comp housings to make it lazier so that it gives smooth progressive power for their cruisers..
The by far best T3 Nissan turbo is the R34 GTT Turbo, it runs the larger OP6 turbine housing as the VG30DET turbo does but a nice chunky compressor wheel. Not a piss fart RB20det compressor wheel like the VG30det turbo does.
And no... its not worth the upgrade for 10rwkw. :mellow:
Highflow the turbo; GCG if you want maximum response with good power, the slide turbo if you want to save a few $$ or see if you can track down a nice little HKS GT2530.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-2597812
  • 1 year later...
Sorry to resurrect an old thread, though I am in the throws of purchasing an R34Gtt turbo to replace the VG30 turbo currently on my RB20DET.
I am trying to get rid of some of the lag.
Will this help given that the R34Gtt shares the same exhaust housing as the VQ30?
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3457832
If i'm not wrong the VQ30 has a bigger exhaust housing to the R34 GTT turbo
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3458086
I'm not sure - I guess that's what I am trying to figure out (as I want less lag and I am told that a larger exhaust housing = more lag). Cubes (above) has written that they are the same and Manwhore (on another thread) agrees.
Edited by Birth
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3458165
VG30 and R34 GTT turbine housings are the same.
The R34 turbo has a slightly larger compressor wheel that is possibly lighter due to the material it is made out of.
It will punch harder when it comes on as a result.
The R33 S2 turbo really is the best pick out of the std turbo's for the rb20.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3458588
Just a question, turbine housing and exhaust housing are the same thing or different? I'm sure the VG30 single turbo is definitely bigger than the R34 turbo in certain ways, thus giving me more power as proven on dyno. Have a friend with a high flow R34GTT turbo put on dyno and my hi flow VG30 turbo on dyno, i have about 10 rwkw more. Not much of a difference though i feel.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3464337
ok, I have bought an R34 turbo with the OP6 exhaust housing as it is a bargin. I am looking at acquiring a new exhaust housing via swap or buy - what should I be looking for, a. one from an R33 turbo because that is what everyone is telling me to buy because the ex housing is smaller than the OP6 or an RB20 housing because that is even smaller than the R33 housing, but the R34 compressor will off-set that with better flow?
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3465451
  • 4 weeks later...
To finish this converstation off - I have installed my R34 GTT turbo. The swap itself was obviously simple. I think that the R34 turbo is better - there is more boost early on and the car feels alot more drivable, though I do miss the surge of power that came on with the VG30. Don't let me be a sook though, if you have an RB20 and you are looking for a cheap upgrade neither is a bad solution (the VG30 is in my opinion certainly better than the RB20 turbo), though I think that the R34 is the way to go.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3509663
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
