my standard HID Xenons got taken out during complience (IM SO FREAKN PISSED) and im left with some shockn lights now. been meaning to get the cosmo blue or something else but i realli want to know something before that happens.
if they took out my HID Xenons....does that mean i cant put xenon globes in anymore? if thats the case i need a conversion huh?
EDIT:: just checked wat type of globes my car needs....normally the R34 GTTs use H1s correct? and H4s for the parking lights? i just noticed some losers changed my lights to H3s......wth and why would they do dat? i think complience may of did this.
can someone tell me the diff between a H1 and a H3....infact wats the diff between em all?
Edited by anDru
https://www.sau.com.au/forums/topic/139395-do-i-need-a-hid-conversion/
lol...
Andru, just buy a new HID set.
yeh for some reason im with u lol.
but lets say i put those M tec cosmo blue globes in my car.....wat would be the difference if i had a HID set and just havn the globes themselves...
lol
Blue light is dimmer than white light in the light spectrum
Blue light makes you drowsy at night
Blue light is shithouse in the rain and in any sort of fog
But if you want to be like all the other ricers with "super white" or blue headlights, go ahead. :sorcerer:
4300K HID's are probably as white and therefore as bright as you can get.
personally i want red....but i havnt seen any.....infact i realli dont like blue or white cuz dats all u see on the roads.....even though its the most logical....i want something diff...i rkn it suit the r34 rear lights aswell...so it all flows good
Here, study this:
Mtec is blue light, thats all. Infact yellow light is much brighter. also my mtec head lights blew up after 2 or so months. i went back to stock yellow ones.
for next headlamps bulbs ill be getting Narvia 50 +, they emit long range light.
that sucks man......most of my mates have the M tec blues havnt had problems for nearli a year.
Andru, I don't know whether you'll listen to me or not, as in the past, you haven't seemed to listen to others, but i'll just give you a few quick points.
Blue/white bulbs are not brighter. they are just rice. they are white because of the blue filter. Essentially, they filter out yellow light and only let through the whiter light. the majority of light from a halogen bulb is yellow.
Plus 50 globes are the best bulbs you can buy. at the 50-70 m, they have about twice the light output. They add xenon gas into the atmosphere of the halogen bulb making it burn hotter and therefore brighter. As a side beenfit, they are also whiter (brighter is whiter - imagine a 25 watt light globe at home, very yellow and dull, compared to a 100 watt globe - bright and white).
hid aftermarket kits are f**king shit. Shit cut off, shit light. Expect to glare others and be defected. That is, not really brighter. shines light in all the wrong ways.
Original xenons for r34 are cheap. i've seen them go for 500-800$.
So either do plus 50 globes + relay mod for max light output using halogen globes.
or get original xenons, biut don't do aftermarket kit.
If you're just in it for looks - those white bulbs are ok if you just want looks. they're just not as bright. if you get one with an overpowered filament with xenon gas and blue filter, it might just be about as bright as a standard yellow halogen globe - not bad.
The reflectors in your headlight housing are what determines the "range" of the headlight, not the bulb
Dark, read what Sir d said carefully. He is correct.
Keep in mind, that a headlight is a very precise instrument. A mm movement here or there completely changes optics. Especially over a range of say 50-100 m when the reflector is only about 10x10 cm.
Now, essentially, what the plus 50 bulbs do is this I said it above, but i'll clarify it more:
They contain xenon gas in the atmospher of the bulb, which makes the halogen cycle occur more efficiently. Therefore, they can overpower the filaments to make them burn hotter and therefore, brighter without them burning out.
It has been tested many times. I have conducted tests myself as part of my and my father's work. In the 50-70 m range, light output is about 50% more.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
