First of all i would like to say a big hey to everyone out there. (as this is my first post :mad:) Love the site tho allways find usefull stuff on here and good advice.
I have a couple of questions about what i should do and have some ideas dont know if they will work or not thats why i came here :( lol
Question 1:
Can a GTS4 be converted to have a RB25DET or would it be pointless cos it would cost to much cos of the fuss with the AWD?
Question 2:
would it be better to just buy a GTST and not worry with the fuss?
Question 3:
how much would it cost to put the RB25DET in the GTS4?
Question 4:
would the rb25det in the gts4 have better peformance than a normal gtst?
thanks in advance :mellow:
Edited by raZ1911
https://www.sau.com.au/forums/topic/139404-awd-rb25det/
  • Replies 40
Which GTS4 (R32 or R33)?
R32 GTS4 only came with a RB20DET.
Stagea RB25DET is the only engine that bolts straight in (in RB25s at least - obviously RB26 is an option).
As to performance, I took my low-mod R32 GTS4 from 115 awkW up to 180 awkW (included aftermarket ECU). You be the judge if it's worthwhile.
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2599046
perhaps buy a GTS4 and also a Stagea frontcut?
use the engine to get you a AWD RB25det conversion, and I know plenty of Stag owners would be interested in the front bar, the bonnet, the side panels, etc. you'd make your money back easy IMO.
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2600168
i may be wrong coz dont know much about 33's but didnt the r33 gts4 have a 25det in it so wouldnt it be easier to buy a 33 gts4??? and as you stated you wanted an r33
ok my bad i figured the 33 was a 25det in the gts4 but its NA thought it would be the same as a 32
Edited by paulmac
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2600786
Question 4:
AWD added about 130kgs to the R32 GTS-T when they created the R32 GTS4. With that in mind, I would say the added weight of the AWD hardware means your car would probably actually be slower than the standard rear wheel drive car in most situations. You must also consider that when the GTS-T isn't just a GTS with a turbo engine - brakes, suspension, wheels, etc. are all upgraded to handle the extra power, and you should consider this when costing a turbo engine conversion for a non-turbo vehicle. Depending on the results you want, it would be far more cost effective to boost traction via. suspension and tyre mods rather than swapping to all wheel drive.
Just my 2c.
would a stagea front cut be hard to get?
If you can't find one in your area, companies like Prestige Motorsport will locate one in Japan to your designated specifications and import it for you.
Edited by Big Rizza
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2601056
would that cost much?
Dunno how much for a Stagea, but I'd say they would be comparable to the equivalent Skyline prices. As a guide:
Nissan Skyline R33 Gts-t Series 1 2.5L turbo 1993 - 95 model (RB25DET) 5 speed manual with good condition engine and body panels
from about $3,800
Nissan Skyline R33 Gts-t Series 2 2.5L turbo 1996 - 98 model (RB25DET) 5 speed manual (hard to source)
from about $4,900
Nissan Skyline R34 GT-T 2.5L turbo 1998 to 2002 model (RB25DET NEO) 5 speed manual
from about $7,100
Front cuts are sourced from Japan as whole vehicles, tested as a running unit, then cut up and shipped as a front cut. Vehicles are chopped just behind the windscreen, and typically include the front seats, engine and wiring, transmission and tail shaft, suspension, wheels and fuel pump. If sourced to order then other small parts not usually taken from the vehicle can be included on request.
More prices at http://www.prestigemotorsport.com.au/modul...rticle.php?t=22
Edited by Big Rizza
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2601313
is that the same with the R33?
from about $3,800
from about $4,900
from about $7,100
yeah ill email them and ask about the cost, is there any other places that do it also just so i can ask around
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2601378
Yes.
Dunno if any of these guys will source half cuts from Japan to spec, but I'm sure they could point you in the right direction...
http://www.justjap.com/halfcuts.htm
http://www.adelaidejap.com.au/front%20cuts.htm
http://www.japimports.com.au/halfcuts.htm
http://www.japanesemotorsport.com.au/engines.htm
Plenty of others out there.
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2601799
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
