I am probably going to start job in the next week or so. I feel alot more confident thanks everyone. I will make my own lines and i can get hold of some heat sleve stuff. One last thing, is it a big deal to adjust the actuators once the turbos are in? Im going to leave the engine in the car.
Good to hear that mate. No problem about the offer, anytime. I'll second the water and oil lines they are a pain in the ass! Very tricky to start the eye bolt without loosing the lower copper washer. Also make sure you dont cross thread them. Make sure the banjo fitting is square on the connection when you try to start the eye bolt.
PS: I also need heat sleeve stuff..lol
Never adjusted actuators as mine are stock..
Regards,
Deren
Sometimes the actuators are set at a higher bar and you might need to after you have completed
the installation, take your front pipes off to adjust.....they only need slight adjustments up or down to get
the results you need.
Both turbos need the same boost level. :)
my friend removed and fitted new turbos on his car not long ago. took him 3hrs out and two hours in.
then i did the same on my car took 4hrs out 2hrs in. we both never did this before.
i thought it was gonna be a nightmare but once you start undoing a few nut n bolts its not actually as hard as
it looks.
all the tools i had was a 56pce spanner socket set and ratchet spanner set.
its a bit tricky but worth the effort if it saves money.
Awesome topic guys im thinkin of doin the same with my GTR by puttin in some GT_SS turbos so when i get round to it your info will definately come in handy
I started removing my turbos, after a gasket leak started getting worse. So at the same time im upgrading from 32n1s to GTSS's and also replacing stock dumps. Its a prick of a job.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
