Okay, this is seriously a newbie question, but I have just put my new stock R33 GTS-T through a dyno to measure the initial power before any mods were done to it.
Why is the max power only at 132kw instead of the 180kw which it was supposedly able to do in the official R33 specifications?
No wonder it felt kinda slow. Kinda dissapointed and can't wait to fit some mods. :laugh:
https://www.sau.com.au/forums/topic/139745-power-output-in-stock-r33-gts-t/
all figures in magzines, flyers, brochers, dealers etc are all flywheel
ie: at the engine / clutch system and not at the rear wheels.
a stock gtst in 4th will make around 130 to 140rwkw.
all the hsv's that have the 250kw badging and "figures" are all the flywheel
so they would make around 200rwkw. a 200rkw skyline would smoke it no worries
The R33's come with a dual stage boost control solenoid that switches from low to high boost mode at roughly 4500rpm (about the same time the variable inlet cam kicks to advanced setting). It's mounted in front of the passenger side strut tower with 1 hose going off to the intake before the turbo, then another with a t-piece splitting off to go to the wastegate actuator & the intake after the turbo.
Why nissan set them up with the dual stage control like this I have no idea, makes the car a lot peakier to drive though. When you get another boost controller you can set it up for the same boost at lower revs. Far more Torquey
Edited by JazzaR33
Mate, my R33 was on the dyno at Mercury a bit over a week ago and it made 149.4rwkw, again on a completely stock car. If you compare the graphs you'll see that i'm making around 20kws more through most of the rev range, but more importantly you'll see the difference in boost. I've grounded the wire going to the boost controller so it's in high boost all the time, but yours should still get there in the end. I'd be looking at your boost controller first, maybe read the thread on staying constantly in high boost mode and give that a shot.
My RB20 made 196.4kw with some small mods. I think the R34 Turbo made a big difference. Dyno Results are on my Signature. Shoebox I suggest you get rid of the Dual Stage boost and just run a constant 8-10psi. >_<
:P
Edited by r32matt
well I had 145rwkw completely stock and when i got an exhaust it went to 170rwkw. how do i do the adjustment to get hi boost from stock controller all the time??? havent heard of that yet. Thanks!!
and it should be at 5psi before that. i'd say you have a split hose of something causeing a boost leak.
okay, i'll ask him about it tomorrow. split hose!?! don't scare me! =_=
but i really doubt that it's a mechanical fault, as i sent this car down for a pre-purchase inspection a few weeks ago, and it cleared except for an oil leak from the tappet covers, castor bushes which are about to split and spark plugs which are one heat range lower than they're supposed to be.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
