Gizzmo one needs the Shift light as well.
Bee-R cuts the entire ignition circuit on and off as required.
The Gizzmo is sequencial so it shuts down cylinder by cylinder.
Factor in the $300 odd for the Shiftlight for the Gizzmo.
PS. If you get the Gizzmo one, I want a full review cos I would love to get one.
BASS OUT
I have both, 200 for the shift light, 170 for the launch controller
Haven't had a chance to wire them up, but as soon as I do, I'll give you a ride in the car Pete :(
(I'm hoping to get some 1.7 60ft times with it hooked up)
  • Replies 77
Dark, is this also a 0kmph rev limiter? I don't want the rev limiter cutting in when moving. Also is it easy to turn off?
Does anyone know of a proper rev limiter like this one without the shift light? And by proper I mean one that shuts down individual cylinders, not the whole ignition circut.
Thanks guys (oh and sorry if I have hijacked this thread)
It works on a clutch switch
So, it only activates the limiter when the clutch is in, so it allows you to flatshift, and keep full boost
You can always hide the shift light in your glovebox or somewhere where its not visible.
If you want something like what you described, Wolf/Motec/Autronic should be able to handle something like that
The Gizzmo also has a rev-limit function.
So there's the clutch limiter and total rev limiter.
The shift light is big, and I wish they made a smaller one.
I was considering pulling one apart and remote mounting the L.E.Ds so that you only have a little L.E.D in the corner of your dash.... That's the ultimate in stealth
Problem is I have a powerfc and a datalogit so its not viable for me to change the ECU.
After something small, that cuts revs with ignition cut, and yeah, minimal stuffing around to install. Wish I had a powerfc pro, or they kept making them :(
i came up with the crazy idea to use datalogit to edit the aircon-on idle RPM to around say 3000rpm in the FC then disable the aircon system (fuse or something) then to activate the launch rpm turn on the aircon (even tho system disabled). the FC would kick up the RPM as the A/C switch is ON and sit at whatever RPM you dialed in but as soon as you tapped the throttle it would drop again. and it could be unsafe, but more than 1 way to skin a cat
:sorcerer:
FC pro exists for r32 and is $1400 brand new from nengun.
you would have to flip the two injectors that the ap engineer guys do.
also load your default 25 maps or current tune. the rest should be fine.
but you will loose the VCT if you do this
actually ill add that to the FC faq as an alternative for the FC Pro on rb25det
its a shame the rb26 FC pro was discontinued, if you can find one of those
you could use that on your rb25, would give you the following
working airtemp
support for twin afms if you want
support for twin 02 sensors if you want
pro functionality
VCT wont work
Paul,
You would need the airflow from the open throttle to rev to 3000rpm.
I think.
The idea is not so much the revs, but the masses of fuel pumping into the manifold and the wide open throttle.
Can't you wire up a clutch switch to the datalogit, and use the antilag? Ovisly you won't get the ignition cut rev limiter.
Antilag is meant to work when your foot is OFF the throttle
It would kind of defeat the purpose of hooking it up to a clutch switch
i read that it dosn't work off the tps, but off the clutch switch. so when the clutch is in (launch, gearchange) it retards the timing and goes bang bang.
But apparently it dosn't work, so that fixes that.
i cant see that being useful on a launch, on gearchanges, yes
do you really want to retard the timing while you're trying to rev/accelerate?
Retarding the ignition heats up the exhuast gas, hence spinning the turbo faster.
That's how Anitlag works. Lots of fuel, retarded ignition.
I thought it retarded timing rather than ignition?
When the driver lifts his foot from the gas pedal the ignition timing is altered with sometimes 40° or more of delay (retard) and the intake air and fuel supply mixture is made richer. The inlet butterfly is kept slightly open or an air injector is used to maintain air supply to the engine. This results in air/fuel mixture that keeps getting in the combustion chambers when the driver no longer accelerates. The ignition being delayed, the air/fuel mixture reaches the exhaust tubes mostly unburned. When the spark plug fires, the exhaust valve is starting to open due to the ignition delay mentioned above. Additionally, the exhaust temperature being extremely high, the unburned fuel explodes at the contact of the exhaust tubes. Luckily the turbo sits right there and the explosion keeps it turning (otherwise it would slow down since its intake, the exhaust gases, is cut-off).
I've just confused myself even more
I'll shut up
379 from otomoto.com.au
bought mine secondhand off yahoo auctions for $80 delivered. Chucked it on my N/A RB20DE with a "race pipe" (no need to worry about ceramic turbines) and scared the ba-jeezus out of everyone when the clutch got dumped.
It now resides on a CA18DET in an actual race car, so its sorta well suited. Which reminds me, there's different Rev Limiters for different engines, RB and CA are the same though.
If you hook the handbrake signal cable up, then you can dial in 2 different max RPM's before cutting ignition. Really good for drag racing, sorta pointless on the track.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
