  • Replies 208
Dunno 4Dirty2, im guessin everyone could put a couple of dollars together, how much were you thinking?
Heard from Hot4s and he is willing to come out and take a group shot for the magazine but will still need someone for shots of our own.
Yeah i think people wouldn't mind as long as it wasn't at all expensive.
Obviously it would only be for those in the main photoshoot as some people may just be coming for a looksee...or to take their own photos...
It'd be cool to get some SAU 'lines in a mag :)
i dunno about 5$ or 10$ an they suply the cd if 10$ other wise bring ya own or sumthin like that
he hasnt asked for anymoney but i just figured it would b nice as his stuff ant cheap an the more money he gets for this the better stuff he can get for other shoots an maybe get a job sum where he can help us in return in the future
pics were taken at the main shopping centre
Edited by 4dirty2
YES
what are the significanse of the cars in your sig 4dirty2
just wondering if you would consider running a mini sig with maybee only the skylines ?
other cars can be added i just personally think 850 pixel wide is a little large... thoughts??
Edited by Madaz
Its a damn sig.. lets not get fussy over it.. althought 850 pixel is rather large.. possible photoshop resize?
lol use say dont get fussy yet agree 850 is rather larger :wave: bit of double dutch
gts33t - You finally get something from Hot4s, what did they say? Are you going to be in the SCS? I would like to go for the photo shot and see other cars, if there is still enough room, but I don't know what time the show finish. Anyway, just another suggestion for you, if you can get those guys from the magazine to come, you may also like to put your car or someone's car to be feature. That's how I had the photo shot from Hot4s with the other group before, it featured 3-4 pages in the magazine for the whole group, looks very good and I remember the group photo has taken 2 full pages in the book already. :wave:
Just likemore skylines the merrier, more photgraphers the better i say, someones gonna get a better picture than someone else, i think everyone can make a donation when getting a copy of the cd from your mate 4Dirty2.
As for Hot4s i dunno if he will be at SCS but he will come take some pics of the big group.
Will send out PMs this week.
mr_rbman if you know this guy you can ask him but i dont know who he is.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
