Hey guys,
I'm looking into buying a stagea, but can't decide on series1 or series2. Apart from the cosmetic changes (not important), the only major difference is the Tiptronic shift, and the S2 has the RB25 Neo engine.
Are there any benefits to the Neo engine??? Apart from factory outputs are rated a 206kw. but thats like all japanese cars so.
Can somebody give me any ideas???
https://www.sau.com.au/forums/topic/139849-rb25-tekkies-look-here/
Neo has upgraded brakes, too
Neo engine is an update model, etc etc, and the turbocharger exhaust housing is slightly larger too.
When I got my series 1, prices for the series 2 were at a minimum 8grand more. I used that 8k for mods to my series 1 Dayz bodykit 1997 Stagea - definately the right choice for me at the time.
good luck with it
Brendan
They have VVT right through the rev range, gtr conrods, use less fuel, have about 60 nm more torque than the older rb25's. Which counts for jack if you mod it but makes it a much nicer car if stock.
My r34 is stock and that extra big dollop of torque down low really helps when just putting around.
I've got a s2, basically because I just wanted the best I could get at the time. The price difference was still quite considerable between s1 and s2.
If you're just after performance and value for money then the s1 is your best option. For the same price as a good s2 you could have a s1 plus enough mods to make it look, sound, and go better than a s2.
My reasons for choosing a series 2 were:
- Looks (actually I like both)
- extra ~20kw
- better fuel economy
- infinitely variable valve timing (i think the earlier rb25 is like on-off)
- direct injection (is this true?)
- newer, so likely less km's
- tiptronic auto
- bigger brakes
I think in the end its personal preference - and the reason I say that is because if you want value for money then get a series 1 - but if you really prefer the series 2 then there's your answer. :)
Wasnt there a difference in turbo internals? one had a steel wheel, the other ceramic, bearing differences maybe? think i heard that somewhere...
TIPTRONIC AUTO!!! Bigger brakes would be good too... what car are Stagea brakes off? they look like silvia brakes, to be honest...
I am doing a Neo6 turbo converion on my RWD stagea. Basically the neo6 engine has a different exhaust cam and exhaust cam sensor. Plus being as it is a later model engine the neo6 has got direct injection (and i am pretty sure it has top mounted injectors not side mounted 1's, it could be the other way around). Although i thought they still had 370cc injectors.
Wouldn't be direct injection, AFAIK... Might be a different fuel rail with the different injectors you mentioned, but that's different to direct injection.
Direct injection is what deisels use, where the fuel is fired directly into the cylinder, not into the manifold ports. Direct injection is only now becoming more common on petrol-powered cars...
Quick clarifications;
1. The RB25 Neo turbo has a slightly larger turbine cover, otherwise the same as RB25 (non Neo) S2. That means ceramic turbine and plastic compressor.
2. Neo has solid followers, RB25 has hydraulic
3. Neo passes 1996 emissions, RB25 passes 1993 emissions
4. Neo has SLIGHTLY stronger conrods
5. Neo has larger intercooler (still side mount, but thicker and taller)
6. Neo has plastic top feed injectors (not the same as RB26 top feed though), RB25 has side feed
7. Neo has infinitely variable inlet camshaft timing, RB25 has simple on/off. Neither have variable exhaust camshaft timing.
8. Neo has higher flowing cat standard, but most get changed for compliance, so it doesn’t matter
9. Neo ECU is “smarter”, so harder to trick with piggy blacks (SAFC, DFA or equivalent). Has a much more aggressive R&R mapping, so you need to be a bit more careful with tuning.
10. The NEO CAS has more outputs for increased timing signal accuracy to the ECU (lower emissions and higher power output).
11. The drive peg on the NEO CAS to camshaft interface is different, so you can’t use non NEO CAS or non Neo exhaust camshaft
12. NEO ECU has different ECU plugs and pin outs, so you can’t use an RB25 Power FC, you need the right model PFC.
That’s about all I can think of.
:mad: cheers :D
:mad: cheers :D
Fark thats all. lol. Cheers mate that is heaps helpfull. Much appreciated.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
