Hey Guys im originally from Mackay born an raised there now live Newcastle well Maitland actually.
But i come back every now an then for a visit to see friends an family there. Havent been back this but probably sometime next year hey
Hows the import seen goin there last time i was home there was an actual import shop there
  • 1 year later...
Im living in Mackay just bought my first skyline in May, a dark grey 4 door, bought a stock one as i dont know much about thm thought it would be a good learning curb as i do her up. Good to have something with a bit of power tho a lot better then a toyota starlet :O
  • 1 month later...
Hey Hey!
Been living in Mackay now for 6 months, came up from Newcastle for a bit of a change. Working at Newlands coal mine.
Got my 1995 r33 in feb this year and loving it! Starting to modify it now. Learning process for me, but getting there...
Ive seen a few r33's and only one 34 in Mackay since i've been here.
Would be good to catch up with anyone to get ideas or tips.
Cheers
represent!!!
i grew up in mackay, been here in brisbane for a couple of years tho. Heading back at the start of december for a mates wedding. THe 32 will be staying at home tho...
cost of flights - $200
cost of fuel to try and drive my belted rb20 home - 1 MILL YON DOLL LARS
which sucks... coz ya need a car to get anywhere in mackay...specially when ya stayin at bucasia!!
  • 1 month later...
  • 11 months later...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
