Yeah i all ready sent them an email Kingy getting the Advan Neova AD08's for the R32 and i'm gonna get them New Hankook Ventus R-S3 285/35R18 for the R33 as they don't make the ad08's in a 35 profile in 285's, mackay roads are to shit house for 30 profiles. They give these new Hankook's a good wrap they are a 7.8 and the AD08's are 8.4 on tire rack so i'll give them ago, slightly cheaper aswell.
Hankooks
Advans
Yeah I borrowed a guard roller and did them myself, turned out pretty good I thought, didnt crack any paint... Not bad for a first try :) haha
They are 265/35 rears, factory arms etc. Just lowered a little bit, probably an inch maybe slightly more.
Still tossing up between rear camber arms or just camber correction bushes, will have to decide and take it in for a wheel alignment sometime soon
Think the camber at the front isnt to bad so not sure if ill bother adjusting front camber
Yeah adjustable arms are nice to have, but if yours is a everyday driver i would go with camber correction bushes because aftermarket arm have pillow ball ends (rose joints) and depending on what brand u buy they tend to flog out a fair bit especially mackay roads. I nearly have the full ikeya formula catalogue on my gtr, they are awesome bits a gear but cost you a arm and a leg...if only i had a spare 2k for front and rear lower adjustable roll centre kits...you wanna sponser me kingy lol
I got a full time job sponsering my own :nyaanyaa: lol...
You would not believe what i got quoted for a light globe at autobarn yesterday... $345 and have to order it in gotta be kidding me...
Is there anywhere in town that sell HID globes off the shelf??
Yeah i done the rounds today only place i could find that stock HID were ashdowns in paget but they didn't have the right one. and were 180 per globe lol
Got a pair off ebay for 110 from melbourne. Hope its the right one so many to pick from.
So I had to roll the front guards on my car today, thought they werent an issue but chewed a bit of tyre turning into a driveway the other night lol so decided to fix it today.
Hopefully all good, didnt do much damage just put a very small dint where one of the screws from the drivers side inner guard hit the other part of the guard but oh well. Not a bad job and it was free
Bored, Thought I'd put photos of my first car up seen as I got a bit nostalgic posting a photo of the engine bay in Bens build thread haha
And what it decided to do on my 18th birthday:
Aftermarket lifters are a no-go in RB30E's
Edited by 89CAL
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
